Just tested ignitor and coil...
Old Feb 11, 2003 | 09:32 PM
Rain_man's Avatar
New User
Default Just tested ignitor and coil...
I tested them according to what it says in helms, and I am a little confused by the results. There are four wires to test for voltage for the ignitor. Two showed about 12 volts. The other two showed millivolts, 11.2 and 63.2. It seems odd that the voltage would be that low however, but they were consistent.
The coil resistance was a bit on the low side, when I tested between the 2ndary winding and terminal A. I got 10.8 ohms, when the range is 12.8-19.2.
Can anybody confirm that I will need to replace both the coil and ignitor?
BTW my spark plug wires have 50k miles on them and their resistance is way below the service limit: ~5 kohm for most wires. Service limit is 25 kohm. I guess spark plug wires do last pretty long...
Old Feb 11, 2003 | 09:59 PM
sgT's Avatar
sgT
Default Re: Just tested ignitor and coil... (Rain_man)
if it reads mV, then its probably 0
are the readings for the ignitor what you are supposed to have?
Old Feb 11, 2003 | 10:08 PM
Rain_man's Avatar
New User
Default Re: Just tested ignitor and coil... (sgT)
odd thing was that when I turned the ignition to off, it would go to exactly 0.
The helms doesn't specify what voltage you should get. Just that you should get voltage. Ugh...
Edit: oops, just noticed that I'm supposed to check the wire betwen the ecm and icm. What's the ecm? The other wire specs between the tachometer and icm...
[Modified by Rain_man, 11:11 PM 2/11/2003]
[Modified by Rain_man, 11:25 PM 2/11/2003]
Old Feb 11, 2003 | 10:48 PM
sgT's Avatar
sgT
ecm = ecu
Old Feb 12, 2003 | 08:04 AM
Rain_man's Avatar
New User
gotcha.... so I think what helms wants me to do is to check to make sure the wire between the icm and ecm is continuous and the same with the wire to the tach.
I figure since when I connect the wire to the voltmeter and battery terminal that there seems to be a complete circuit that it passes these tests correct?
GraphiteMW
Nov 7, 2006 03:55 PM
98coupe
Aug 30, 2005 05:22 PM
kevino002
Jun 8, 2005 11:05 PM
KekeK-18
Mar 29, 2004 05:40 PM
bey
Oct 31, 2003 06:13 PM
