just did the head gasket AND???
Old Apr 5, 2009 | 01:57 PM
97hatchgsr's Avatar
Default just did the head gasket AND???
well like it said just did a head gasket and started it and fired right up. Now it has ran for about 20mins and then we went to take off and it just stalled so he tried to start it back up and nothing but cranking. I checked for spark and there is none but we are smelling fuel, in fact alot of fuel. I told him to crank it again and it wouldnt it just stopped so ??? hydro locked. I pulled the plugs and yep the 3rd cyclinder is just filled up to the valve cover and flowing out of the top of it so i unplugged that injector to see if it is stuck and well we are stuck now and dont know where to start... Its a 97 hatch with a gsr swap..
Old Apr 6, 2009 | 02:00 PM
dtapia's Avatar
Default Re: just did the head gasket AND???
did you hook the ground wire ? is the cel light on ?
Old Apr 6, 2009 | 07:20 PM
97hatchgsr's Avatar
what ground wire? like i said the car was running good til he tried to take off then it shut off and now we have no spark still and 2 injectors are dumping fuel..
Old Apr 7, 2009 | 03:10 PM
stevenDAtegra's Avatar
There is a ground wire from the valve cover to the chasis but not sure if dtapia is referring to that one.
Old Apr 7, 2009 | 03:28 PM
dtapia's Avatar
I was refering to the ground wire at the thermostat housing.but now their is other issues. Is the check engine light on ? Is their any stored codes ?
Old Apr 7, 2009 | 07:35 PM
97hatchgsr's Avatar
the only code is iat which would not make it do this but ill check them again. Btw the ground wire is hooked up all of them are..
Old Apr 8, 2009 | 06:25 PM
PyroProblem's Avatar
Injector wires shorted to ground? (full open)
Old Apr 8, 2009 | 06:37 PM
srmofo's Avatar
damn thats alotta fuel. make sure to unplug the distibuter working around all that fuel. One stray spark from a dizzy that you think isnt working and some plug wires laying in a pool of gas and that baby is a BAR-B-Q. Start by finding out what is causing all the fuel, like he said^
Old Apr 8, 2009 | 11:29 PM
97hatchgsr's Avatar
Ok. There is no shorts i've checked everyything I can
That's y I'm askin u guys for help
Old Apr 9, 2009 | 05:04 AM
srmofo's Avatar
well I can tell you with a fair amount of confidence that its not a mechanical problem. What have you checked and what did you check it with? Have you even checked NOID yet? SOmething is causing it to dump hHUGE amounts of fuel into the cylinder, Its either going to be a short or a tuning issue, or serioussly bad bad stuck open injector. I dont know if it is even possible for an injector to go bad like that. its easy to checj though, just swap it with another and if the problem doesnt follow it, then its not bad. We cant hold your hand through this, there is no magic answer. Do you have wiring diagrams, Im sure someone can get them for you if you dont
Old Apr 9, 2009 | 11:49 PM
97hatchgsr's Avatar
well u might be right on the tuning part they put a gizmo on it when it was running before to adjust alittle more fuel and sooner vtec should i have them disconect it and see what it does? also what would shut the spark off like that after it stalls and wont start back up?
Old Apr 10, 2009 | 08:00 PM
Map and TPS connectors swapped? I know its a dumb question...
Do you have access to "noid lights"?
This will tell you if your injectors are being "told" to stay open and will help tell you if its a mechanical or electrical problem since your injectors seem to stay open...
Old Apr 11, 2009 | 03:41 AM
crxsirvtec's Avatar
i had that problem..
ended up being the computer..
and i have 450cc injectors.. imagine that amount of fuel..
once you fix it.. change your oil... (gas will leak into the oil pan)
Old Apr 11, 2009 | 03:07 PM
97hatchgsr's Avatar
ok well we got the new injectors in and we are goin to check some wires and see if its something else, and i just got the noid light... so what do u guys think would make it lose spark? and is there anyway of knowing for sure if the map and tps is on the wrong plug..
Old Apr 11, 2009 | 04:44 PM
srmofo's Avatar
easist way is a scan tool, but if you get a wiring digram the colors are different....you can also mix up the IACV and the IAT. those wires are different color also.
If the injectorer noid is good and not a steady light then move on to the spark issue. I just have a hard time believing you filled up only 1 cyclinder without there being a short to ground somewhere
Old Apr 11, 2009 | 05:20 PM
97hatchgsr's Avatar
i went ahead and checked it just now with the noid and all the injectors are stayin on when the key is on. i need a wiring diagram so i can see where this one plug goes its a 2 wire plug that is hanging right under the battery but its got enough wire to go to the altenator so i have no idea where that goes..
Old Apr 11, 2009 | 09:18 PM
srmofo's Avatar
pics???
Old Apr 11, 2009 | 10:02 PM
rip94delsol's Avatar
How long are the injectors supposed to stay on?
Old Apr 12, 2009 | 08:24 AM
97hatchgsr's Avatar
idk how long i just know that they were on and would not shut off all the injectors are like that. and u can hear something on just humming..
Old Apr 12, 2009 | 03:18 PM
srmofo's Avatar
if you have noid lights hooked up, they will flash rapidly...the faster the rpms, the faster they flash. If you have a scan tool they are measured in Millisecs. way to fast to count, but thats not the issue. If they are not flashing at all, but are constant then there is a short to ground. unhook the ecu, and ohm the yellow/black wires on the injectors. There should be no continuity. if there is then start looking for the pinched wires. if there isnt then try another ecu and check noid again.
Old Apr 13, 2009 | 06:20 AM
97hatchgsr's Avatar
ya i think its the ecu do they just go out like that or what? could the safc did that? anyway im goin to just try a new ecu if that fails then its to the wires and searching for a problem but liek i said it ran perfect before then he tried to take off and boom its dumping fuel and there is no spark...
Old Apr 13, 2009 | 11:46 AM
92_civic's Avatar
double check your wiring on the safc install...that was the only other thing done while the head was off right?
Old Apr 14, 2009 | 07:18 PM
97hatchgsr's Avatar
no it ran wiht it but im about to disconect the ecu and check continuity on the fuel injector plugs, and if there isnt then its the ecu
TeamFrankenmerc
Mar 25, 2018 09:36 AM
Cashieboi
14
Oct 2, 2006 07:19 PM
shipsaeki
Nov 7, 2002 11:48 AM
