just bought new engine what to do before install?
Old Aug 22, 2004 | 09:22 PM
ludewithanh22's Avatar
Default just bought new engine what to do before install?
I just bought an h22a. Its sitting in my garage right now. I took off the intake manifold its very dirty, black grease all through it. Has mildew where spark plugs at. What should i do before i put this engine into my car?? Its not in as good shape as i hoped. its a 1991 h22a.
Old Aug 22, 2004 | 09:26 PM
GZERO's Avatar
Default Re: just bought new engine what to do before install? (ludewithanh22)
well, since i'm not there to see the engine and analize it, i would say, rebuild it, seriously, think about all the effort you're going to be putting when swaping that engine and realize it had a bad ring, or whatever, i dunno.
I'm a mechanic and i wouldn't mind putting it in and out a couple of times, but if i had the money i would rebuild it, if not, at least i would change the seals and maintainance stuff, like water pump, timming belt, balancer belt, etc...
BTW: do you do your own work, or you'll be paying for it? (no offense, just to give you better pointers)
Old Aug 22, 2004 | 09:38 PM
well i would be paying for a rebuild since i dont know how. Ive never done anything like that before
Old Aug 22, 2004 | 09:39 PM
BTW the engine comes with startup garantee. So i can still take it back
Old Aug 23, 2004 | 04:50 PM
GZERO's Avatar
Default Re: (ludewithanh22)
well, in that case a rebuilding is expensive, remember that if you're going to do things, do them right the first time, definetly i would change maintainance stuff just to be on the safe side.
Old Aug 23, 2004 | 06:57 PM
SJcivic's Avatar
Default Re: (GZERO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GZERO &raquo;</TD></TR><TR><TD CLASS="quote">well, in that case a rebuilding is expensive, remember that if you're going to do things, do them right the first time, definetly i would change maintainance stuff just to be on the safe side.</TD></TR></TABLE>
Good advice for cheap insurance... spend the $150 and replace a few things and dont worry about them.
Rich
Old Aug 24, 2004 | 12:43 AM
tjohnson329's Avatar
get a haynes manual and change the timing belt and spark plugs have the heads cleaned at a local shop. do everything you possibly can. it isn't that hard to work on these engines the hardest part is getting them out the car and this engine already is out.
Old Aug 24, 2004 | 07:37 AM
how much does it cost to have the heads cleaned? I planned on changing the belts, spark plugs, spark plug wires and of course changing all the fluids.
Old Aug 24, 2004 | 08:19 AM
-Trinitron-'s Avatar
there is so much maintenence-wise that is so much easier with the motor out. Timing belt, manifold gaskets, belts, etc. Just get the manual for your car and go through it. It is very detailed and has pictures too! Good Luck
OTT
Feb 10, 2004 02:56 PM
OTT
Feb 10, 2004 08:37 AM
Origin
10
Oct 28, 2003 11:29 PM
92accord4life
Jun 4, 2002 03:47 PM
