jun stage 3/compression ratio ?'s...............................
Old Apr 24, 2003 | 09:37 PM
mkhooaah's Avatar
Default jun stage 3/compression ratio ?'s...............................
I have a b18c5 and have jun stage 3's ready to go in(have complete valvetrain upgraded). People are telling me that jun stage 3's do not work well with the stock CR of the motor. Is this true and if so, what kind of CR works best or would I be better off just getting different cams?
thanks alot
Old Apr 24, 2003 | 10:10 PM
crazyitr's Avatar
You need 12:1 to 12.5:1. That's what the Jun crate motors run
Old May 13, 2003 | 12:02 PM
shadyCTR's Avatar
Default Re: (crazyitr)
it will be a dog at low end! but it will pick up at top!
Old May 13, 2003 | 12:16 PM
WAFFLES's Avatar
Default Re: (shadyCTR)
blah blah blah...you will do just fine with a stock bottom end. Obviously, more compression is better, but you will be fine. Consider a Mugen headgasket.
Old May 16, 2003 | 11:09 AM
Scotty B's Avatar
Default Re: jun stage 3/compression ratio ?'s............................... (mkhooaah)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mkhooaah &raquo;</TD></TR><TR><TD CLASS="quote"> I have a b18c5 and have jun stage 3's ready to go in(have complete valvetrain upgraded). People are telling me that jun stage 3's do not work well with the stock CR of the motor. Is this true and if so, what kind of CR works best or would I be better off just getting different cams?
thanks alot </TD></TR></TABLE>
jun 3"s love compression......they absolutley rip with high cr. espesially up top!!!!i run them with ctr pistons and it goes.(i am pretty sure my comp. is 12.1.1 , but some say 10.8.1.......but it sounds and feels to good to be that low. just wait a little longer and do the bottom end. Im me if you got any questions!
Old May 23, 2003 | 09:15 PM
advanracing62's Avatar
Default Re: jun stage 3/compression ratio ?'s............................... (nasi)
I'm planning on running 13:1 compression with JUN III head.. I'm hoping that she'll be a good combo, as long as it clays out.
Old May 23, 2003 | 11:21 PM
sgT's Avatar
sgT
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nasi &raquo;</TD></TR><TR><TD CLASS="quote">
jun 3"s love compression......they absolutley rip with high cr. espesially up top!!!!i run them with ctr pistons and it goes.(i am pretty sure my comp. is 12.1.1 , but some say 10.8.1.......but it sounds and feels to good to be that low. just wait a little longer and do the bottom end. Im me if you got any questions!</TD></TR></TABLE>
Unless you have a b16B motor then your compression is well over 12:1.
kornerk12
Jun 3, 2006 09:43 PM
slowassgsxr750
Nov 28, 2005 05:02 AM
austrian type-R
Jul 2, 2004 05:20 AM
Tuney
Jan 21, 2003 09:16 AM
