jdm type r 4-lug conversion?
Old Dec 11, 2002 | 09:16 PM
JICsube's Avatar
Default jdm type r 4-lug conversion?
im pondering on getting this set up, if a rotor,brakepad,etc. or something breaks will i be up shiet creek, cause the lug conversion is different from us specs? i dont want to have a warped rotor or something else go wrong and cant get it fixed
Old Dec 11, 2002 | 09:47 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: jdm type r 4-lug conversion? (axion7606)
good question, but i think although the lug pattern is 4x114.3, there is parts readily available. but all in all, im curious too, just so i know, knowledge is power
Old Dec 11, 2002 | 10:27 PM
Shawn C's Avatar
In The Garage
Default Re: jdm type r 4-lug conversion? (SIXTYdashONE)
you guys talkin about the 96 civic type-r 4 lug? i thought it was the 90-97 accord and 92-96 prelude lug pattern but what the hell do i know me
Old Dec 11, 2002 | 10:33 PM
JICsube's Avatar
Default Re: jdm type r 4-lug conversion? (22lbGS-R)
i think it was type r but im not really sure, but i do know im gettin a deal thats why i wanted to know, so a year later when something happens i can fix it easily.
anyone know?
Old Dec 11, 2002 | 10:53 PM
Shawn C's Avatar
In The Garage
i think the 96 ctr is the only 4-lug type-r ever. NOW I COULD BE WRONG... but make sure of exactly what it is that youre getting before you do anything else. and what kind of car do you have?? you gotta tell us this ****
[Modified by 22lbGS-R, 7:54 AM 12/12/2002]
Old Dec 11, 2002 | 10:59 PM
JICsube's Avatar
it is the type r, he said lug pattern is 4x114.3
Old Dec 11, 2002 | 11:17 PM
VX's Avatar
VX
From what i've learned, the Integra Type-R in Japan had 4 lug wheels (4X114.3) from midway in 1995 to 1997. I'm thinking about getting this conversion myself, but i'm wondering what aftermarket companies makes brake components for this setup... Anybody know?
Old Dec 12, 2002 | 12:30 AM
Shawn C's Avatar
In The Garage
Default Re: jdm type r 4-lug conversion? (VX)
cool. i try to learn somethin new every day, now ive learned somethin. its 3:30 in the morning, i can go to sleep now.
Old Dec 12, 2002 | 02:49 PM
JICsube's Avatar
bump! anyone? somones got too know this
Old Dec 12, 2002 | 05:41 PM
JICsube's Avatar
ok after a lil researching i found out the older accords have the same lug pattern(4x114.3)so would that mean i would get accord rotors? an what would i use for brake pads? gsr? type r? etc..
Old Dec 12, 2002 | 09:15 PM
Peter K's Avatar
New User
I'm not sure if this would work..but i was contemplating the same things you guys were. This is what i came up with....
1. get the swap
2. get 93-96/ 97-02 prelude/integra type r/ accord wagon calipers
3 get 93-96 prelude rotors... 4x114.3 and 11 inches
swap it all in..
[Modified by Peter K, 1:16 AM 12/13/2002]
Old Dec 13, 2002 | 09:43 AM
Katman's Avatar
I actually helped a ffriend (ff ryan) slap this 95.5-97 4x114 ITR sus type on his Delsol this past weekend. FFrom past experience, you can use any 90+ Accord/Prelude rotors with this sus. As for brake pads, you have to use 94+ non-R Integra brake pads since the calipers are exactly the same as all 94+ non-R US integra's.
and btw... there were no 4-lug CTR's ...ever, only 4-lug SiR's.
[Modified by Katman, 10:44 AM 12/13/2002]
Old Dec 13, 2002 | 02:03 PM
JICsube's Avatar
Default Re: jdm type r 4-lug conversion? (Katman)
ah now for another question, will that jdm 4 lug conversion bolt directly to my eg? or is the hole for the axle going to be bigger then the one on mine? (gsr axles) since i heard jdm 5 lug conversion is bigger then the u.s. specs.
Old Dec 13, 2002 | 02:52 PM
Katman's Avatar
Yep it sure will.
Like I mentioned, we put this 4x114 ITR sus on a Delsol this past weekend. Any US Integra axles will plug into the front 4x114 wheel hub/bearing(s), its the normal 32mm size, not the 36mm size found on JDM only 98+ ITR wheel hub/bearings (also found on CRV's).
Old Dec 13, 2002 | 03:02 PM
JICsube's Avatar
thanks you have been quite helpful!
Old Dec 13, 2002 | 03:15 PM
Katman's Avatar
np.
Old Dec 18, 2002 | 12:01 PM
VX's Avatar
VX
Do any aftermarket companies make performance (bigger) rotors / calipers for this swap (4x114.3)???
Old Dec 18, 2002 | 10:14 PM
Katman's Avatar
look into 92-96 aftermarket prelude rotors...those are 4x114
Old Dec 18, 2002 | 11:47 PM
VX's Avatar
VX
thanks again katman!
Paulie Pesos
Jan 24, 2010 06:10 PM
TURBO DC2
Jul 28, 2005 07:52 AM
Jdmspooge
Jul 13, 2004 05:41 AM
