JDM tranny probs
Old Jun 14, 2003 | 12:22 PM
AznPimpS's Avatar
Default JDM tranny probs
i have a 94 JDM H22A tranny with a few problems
i just filled the tranny with some fresh 10w-30 oil
-second gear seems to grind everytime i shift
-5th gear pops out all the time and has to be held there with force to keep it in
-and downshifting to second gear is impossible
can anyone tell me the cure to these symtoms or do i have to buy another tranny and rebuild it? ( last resort choice)
Old Jun 14, 2003 | 02:02 PM
-Racer X-
Guest
Posts: n/a
Default Re: JDM tranny probs (AznPimpS)
linkage? is it hooked up correctly with no bends or messed up bushings?
Old Jun 15, 2003 | 01:05 AM
AznPimpS's Avatar
i will have to double check the linkage/washers/bushings and cotter pins
1st ,3rd, and 4th gear seems to go in like a glove...?
so "assumming" that there was no problems with the linkages etc...
what would be the next best guess work to solve the symtoms? i want to make my last choice on taking it to AAMCO
thanx for the replies
Old Jun 15, 2003 | 02:16 PM
AznPimpS's Avatar
linkages are hooked up correctly
bushings are good
pins are in tact
washers are good
now what?
Old Jun 15, 2003 | 04:17 PM
riceboyEFsi's Avatar
pressure plate? or your tranny
Old Jun 15, 2003 | 05:18 PM
Dgr8wun's Avatar
its common on the h22 trannies for 2nd to wear out faster than the others... maybe its time for new synchros
Old Jun 15, 2003 | 08:13 PM
AznPimpS's Avatar
new sycros and gear set it is
Old Jun 15, 2003 | 09:29 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AznPimpS &raquo;</TD></TR><TR><TD CLASS="quote">i just filled the tranny with some fresh 10w-30 oil</TD></TR></TABLE>
Using a better transmission lubricant couldn't hurt and might help slightly. Motor oil is not ideal.
Old Jun 16, 2003 | 08:06 AM
AznPimpS's Avatar
i'll try to use better lubricant
maybe some synthedic? or lucas oil?
it will probably make the second gear crunch teeth less than it is now , but as for 5th gear it really forces it way to come out , almost to the point where i hold it in and the gears lock up and the whole car clonks
Old Jun 16, 2003 | 09:32 AM
hndarcrb18c1's Avatar
Default Re: (AznPimpS)
Get honda MTF from the dealer....
cfrank89
21
Nov 27, 2011 05:42 AM
jordan_rael_420
Oct 18, 2010 04:57 PM
Honda Sport
Mar 20, 2006 02:12 PM
JDMH22ACivicSi
Jan 28, 2004 03:22 PM
