J1 cable tranny problem..HELP!
Old May 16, 2007 | 12:20 AM
nightrider93ex's Avatar
Default J1 cable tranny problem..HELP!
Gears go in while the car is off.....when it turns on and in neutral.....the gears dont go in with the clutch engaged .......changed the tranny....new clutch..flywheel..TO bearing..and linkage........when the car is off and put it in first or reverse then turn it on...the car will go like if there was no problem...put it in neutral then the same problem...they wont go in....HELP!
Modified by nightrider93ex at 2:09 AM 5/16/2007
Old May 16, 2007 | 01:20 PM
Default Re: J1 cable tranny problem..HELP! (nightrider93ex)
uh bump....
Old May 17, 2007 | 06:27 AM
4g hatch's Avatar
do you have your clutch cable adjusted to tight
hondateg10
Aug 14, 2007 12:00 PM
geces23
Nov 29, 2006 08:17 PM
spooncivic01
Jul 8, 2006 06:13 AM
Demon_Dub
Sep 17, 2004 03:17 PM
