ITR valves in B16A
Old Nov 18, 2002 | 07:29 PM
Ovl55rag's Avatar
Default ITR valves in B16A
Did a search and came up with nothing. Will ITR intake valves drop right into a first gen B16a. Tell me what needs to be done. Shop is waiting for my next step.
Old Nov 18, 2002 | 08:40 PM
InevitableRace's Avatar
Default Re: ITR valves in B16A (Ovl55rag)
The intake valve are diffrent and they are bigger and the flow better then GSR and a B16a intake valve.....The exhaust valves are the same on all motors so just change the intake valves.....
Thanks
Ross
Old Nov 18, 2002 | 09:24 PM
sgT's Avatar
sgT
Default Re: ITR valves in B16A (allmotrb18c1)
Thanks
Ross
Ummm NO. they are the same size. the seat angle is different so you will have to
have the seats cut so that they will seal.
Exhaust are the same
Old Nov 18, 2002 | 09:42 PM
b19coupe's Avatar
Default Re: ITR valves in B16A (sgT)
And ITR (intake) valve stems are thinner at the head of the valve to help flow
[Modified by b19coupe, 6:43 AM 11/19/2002]
Old Nov 18, 2002 | 10:59 PM
AJ PwR's Avatar
They are same as the B16 valves but you need to lap the valve seats before you install it.
Old Nov 19, 2002 | 08:28 AM
Chugger's Avatar
Default Re: ITR valves in B16A (AJ PwR)
how do you go about lapping the seats
i am wondering because i might be going thise route in my gsr head
thanks
chris
Old Nov 19, 2002 | 09:20 AM
JCushing's Avatar
whats the advantage to R valves then? do they flow better? i do understand that they are lighter but am just wondering if they will provide any more air flow
Old Nov 19, 2002 | 09:43 AM
-16V-'s Avatar
Default Re: ITR valves in B16A (JCushing)
i'm stuck On the same thing trying to upgrade my valve train but dont know which route to go with?
It's for a n/a motor
I would like to go with a WHOLE NEW valve train along with some ctr cams?
So what can i keep from my old b16 valve train?
I know when buying ctr cams they tell you just to buy the intake one, so could you still keep your b16 exhaust cam?
O yea one more ? how would my car run if i have a new valve train and using you stock b16 cams? could i rev higher????
ferio-ichi3
Sep 19, 2013 08:31 PM
turbohf
Feb 4, 2007 06:09 PM
SPOOLINmatt
Dec 29, 2005 10:01 PM
evo
Oct 4, 2002 12:09 PM
TRuST
Jun 16, 2002 10:48 AM
