itr suspension on ef
Old Jul 12, 2004 | 09:55 AM
hatchlessrex's Avatar
Default itr suspension on ef
i asked this question on the ef forum and havent recieved an answer yet. i was wondering how yon can make an itr suspension like tein or buddyclub fit a crx. i was told that you can use the rear lower control arm from an itr and the front forks from an eg. i was hoping that this was the answer.
Old Jul 12, 2004 | 10:15 AM
_BEN_'s Avatar
Default Re: itr suspension on ef (hatchlessrex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchlessrex &raquo;</TD></TR><TR><TD CLASS="quote">I was told that you can use the rear lower control arm from an itr and the front forks from an eg.</TD></TR></TABLE>
That is correct.
The front shocks are about 1/8" larger in diameter thats why you need the different forks. Those can come off of any dc or eg.
And the rear shocks are like a lolly pop on the bottom instead of a fork. You will need the rear lca's off of a itr, 88 usdm EF, or any jdm dc,eg or ef. Because all of the jdm models came with that style rear arm for some reason.
Old Jul 12, 2004 | 10:40 AM
Default Re: itr suspension on ef (_BEN_)
do you know of anyone who has used the tein flex with edfc on an ef yet (flex for itr that is)?????????
Old Jul 12, 2004 | 03:06 PM
_BEN_'s Avatar
No, But I have used ef and dc suspension on a eg. The ef suspension was longer in the rear and the front was about the same.
As long as the shock bodies are threaded you should be good to go.
RED_90TEG
Dec 20, 2007 12:15 PM
Petah
Apr 11, 2006 05:02 PM
Egezzy
Jul 27, 2005 07:44 AM
red civic standard
Jan 19, 2004 06:08 PM
lsvteceg
Nov 11, 2002 05:24 PM
