ITR Final Drive
Old Dec 11, 2002 | 08:00 AM
TheHater
Guest
Posts: n/a
Default ITR Final Drive
Is it worth adding this on a honda civic si 99? and what does it actually do?
Old Dec 11, 2002 | 10:05 AM
Kataku2K3's Avatar
Default Re: ITR Final Drive (BOOSTINSI)
If you are refering to the JDM 4.785 then it is just going to make you gears even tighter... The higher the FD the closer it brings your gears together and vise versa. I really wouldn't add one to your 99 Si because that tranny already has pretty high gears... the FD isn't high it's just the gears are made so... For around the same price I would just look into LSD's Quaife??
Old Dec 11, 2002 | 10:07 AM
shamoo's Avatar
Will you make something up for me please?
Well...just as an FYI, the USDM Integra Type R and your Civic Si both have the same 4.400 final drive.
If you have the B16A2, which I suspect with the SC4 or Y21 tranny, then you also have the same gear ratios as the ITR as well.
The JDM Integra Type R has a 4.785 final drive.
EDIT: Damn JDM, you smote me to it.
[Modified by shamoo, 2:08 PM 12/11/2002]
Old Dec 11, 2002 | 10:13 AM
Nameless RB26's Avatar
Default Re: ITR Final Drive (shamoo)
If you put the JDM FD in, you're going to like it...
I guarantee it will feel different than stock..
Old Dec 11, 2002 | 10:15 AM
I don't believe the gears are the same on the 98+ JDM trannys as the B16a2.
Old Dec 11, 2002 | 10:31 AM
Kataku2K3's Avatar
haha, i just got on cuz i was bored and was like "i wonder how come no one has posted in here", we were probably typin at the same time... hehe... Latez
6pucker
May 4, 2005 06:38 AM
ViperbitGSR
Mar 14, 2004 03:04 PM
whoobeedoobee
Sep 5, 2003 04:51 AM
gsr98vtec
Jan 2, 2002 07:42 PM
DelsolVtec18
Sep 29, 2001 11:00 AM
