JDM final drive
Old Sep 26, 2001 | 09:22 PM
DelsolVtec18's Avatar
New User
Default JDM final drive
Dumb question??? What is a JDM final drive
Old Sep 26, 2001 | 09:30 PM
HXMan's Avatar
Default Re: JDM final drive (DelsolVtec18)
You know about gear ratios right? Well, a JDM final drive is a HIGHER final drive gear that comes out of a JDM ITR and CTR. The final drive is higher then the stock final drive gear of the USDM ITR or Si.
Old Sep 27, 2001 | 11:18 PM
markpaco's Avatar
The gears are lower rather. The ITR is 4.785. But the CTR is 4.400 along with the GSR, Del Sol VTEC, and 99+ Si.
Old Sep 28, 2001 | 02:15 PM
Katman's Avatar
..in general..
A final drive is the final set of gears...or gear.. that the transmission has to communicate through in order to put power out to the axles/wheels.
Every car has a final drive.....
When the spec or ratio of the final drive is changed - whether higher or lower geared, it has a dramatic effect on acceleration.
now...
a "JDM final drive" can mean many things.....You need to be more specific.
But, I bet you're wondering about the JDM 4.785 final drive, which is only found on the JDM 98.spec ITR. The 4.785 FD (final drive) is one tight ratio....which will make the 1-5 gears shorter as a whole. Any B-series DOHC VTEC hydro tranny(US & JDM), other than a JDM 98.spec R have a 4.40 FD. The 4.785 is more 'race' oriented, hence the "R" in Type-R. Acceleration is incredibly increased and is totally noticeable-also adding some 15% more torque to the powerband with a 4.785 or any other aftermarket FD available on the JDM market. However, the 4.40 FD is more of a streetable FD - I'm not saying that the 4.7 is BAD, but....a lot of people on the net, W H I N E about how high they're 5th gear is and how they can't stand the high revs on the freeway - boo fawkin' hoo you retards!! - you shoulda known what you were getting into when buying a 4.7 FD!
hope this helps...
I think I might have left out some information, due to my hunger crisis of not eating lunch yet....grey matter is being lost.
[Modified by Katman, 3:16 PM 9/28/2001]
Old Sep 28, 2001 | 02:47 PM
court's Avatar
25 Year Member
Default Re: JDM final drive (Katman)
fd= rear end
Old Sep 28, 2001 | 02:54 PM
Katman's Avatar
Default Re: JDM final drive (court)
fu=final umph
Old Sep 29, 2001 | 11:00 AM
Bumnah's Avatar
looks like kitty katman is laying down the law again.
faSHOwidIT
Mar 13, 2006 12:33 AM
faSHOwidIT
Mar 12, 2006 06:01 PM
DelsolVtec18
Sep 27, 2001 01:14 AM
