intermittently high idle
Old Jul 26, 2004 | 10:07 AM
suspendedHatch's Avatar
Default intermittently high idle
Most of the time, but not always, when I come to a stop the idle is a few hundred RPM high. It just started doing this out of nowhere. If I blip the throttle, it sinks down to a normal idle speed. So I'm thinking the throttle cable is getting bound up somewhere. Well I put some oil on the throttle spring and the part of the cable where it tucks into the rubber sleeve, no dice. Is there somewhere else I need to lubricate? Or am I on the wrong track?
Thanks.
Old Jul 26, 2004 | 04:25 PM
Fobtions's Avatar
Default Re: intermittently high idle (shaundrake)
when my brake master cylinder was going out that is what it did.
Old Jul 26, 2004 | 08:57 PM
Default Re: intermittently high idle (Fobtions)
Master cylinder or brake booster? I don't see how the master cylinder could in any way affect the idle. Besides, my master cylinder is only 5 months old from when I did a four wheel brake swap.
jceron64
May 28, 2011 07:32 PM
KLiK
Apr 19, 2010 07:33 AM
D16Z6racing
16
Aug 12, 2008 11:57 AM
Tarlacon
Mar 22, 2008 07:48 AM
