Intermittent startup issues
Old Mar 24, 2008 | 11:45 PM
Crono139's Avatar
Default Intermittent startup issues
This has been happening since August/September, but prior to it happening this past Saturday, the last occurrence was in November, or so. It's not an everyday thing, which is what is so weird.
What happens is, as soon as I start the car, it dies within seconds, and completely shuts off. If I try to start it up again, you can hear it cranking, but the motor just won't turn over. However, if you let the car sit for at least a few minutes, the engine will usually turn over without problems. Once the car is running, everything works fine.
<u>Events from last Saturday</u>:
3:45PM - Car started, but immediately died. Attempt to restart car fails.
3:50PM - Attempt #2 fails
4:00PM - Attempt #3 fails.
4:45PM - Attempt #4 is a success (I let the car sit until my dad got home from work)
I don't believe that it's the battery, distributor, or starter. All have either been tested, or replaced.
<u>Haynes manual says</u>:
1) Loose or faulty electrical connections at the distributor, coil, or alternator
2) Insufficient fuel reaching the fuel injectors
3) Vacuum leak at the gasket between the intake manifold and throttle body
Your thoughts? Thanks in advance.
Old Mar 25, 2008 | 11:14 AM
Crono139's Avatar
Default Re: Intermittent startup issues (Crono139)
Bump.
Old Mar 25, 2008 | 12:49 PM
Perfectionist's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crono139 &raquo;</TD></TR><TR><TD CLASS="quote">
What happens is, as soon as I start the car, it dies within seconds, and completely shuts off. If I try to start it up again, you can hear it cranking, but the motor just won't turn over.I don't believe that it's the battery, distributor, or starter. All have either been tested, or replaced.
If the main relay isn't working, that might explain the short run period followed by no start at all. The engine uses up what little fuel may be left in the fuel rail and dies. The main relay provides power to the pump and injectors for the 1 or 2 seconds after the ignition is first turned to run (while the CEL is lit), then again once it gets a signal that the engine is turning. Listen for the hum of the fuel pump during this period.
Old Mar 25, 2008 | 02:21 PM
Crono139's Avatar
Default Re: Intermittent startup issues (Perfectionist)
I'll listen for the fuel pump whine at EVERY startup from now on.
I know it whines when the car starts up fine.
DKYamada
Aug 31, 2009 07:51 AM
96b18c
Jun 1, 2004 10:33 AM
c-y-nickel
Mar 16, 2004 04:24 PM
Buckkaaaa!!
Jun 30, 2003 08:57 PM
