Interior Light Problem
Old Nov 11, 2002 | 06:43 AM
Neptune's Avatar
Default Interior Light Problem
I just got a 97 Civic EX coupe and the interior light won't come on when the door is open. I can turn it on and off using the switch but when it is in the middel position where the light will come on when the door is open it won't. Do I need to rewire it or what? Thanks
Old Nov 11, 2002 | 06:50 AM
Crazydave's Avatar
Default Re: Interior Light Problem (AmericanWagoner)
I have the same problem..
did you replace the bulb???
I'm too lazy to buy a new bulb .. and dig out the volt meter to check the socket
(mine looks ok)
Old Nov 11, 2002 | 06:55 AM
Neptune's Avatar
Default Re: Interior Light Problem (Crazydave)
Yea, the bulb works fine, it is just when it is in that position that it won't cut on. Kinda odd, anyone else know what the problem is.
Old Nov 11, 2002 | 08:00 AM
DillHole's Avatar
Its the door switch. Unscrew the switch, it's probably rusty. Clean off all rust with wire brush or sandpaper, same on body metal also, then reinstall and tighten.
Old Feb 1, 2004 | 06:02 PM
BMac86's Avatar
Default Re: Interior Light Problem (DillHole)
Sorry to bring this thread back from the dead, I had this prob too. All fixed now! teehee
Old Feb 1, 2004 | 06:17 PM
Kendall's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DillHole &raquo;</TD></TR><TR><TD CLASS="quote">Its the door switch. Unscrew the switch, it's probably rusty. Clean off all rust with wire brush or sandpaper, same on body metal also, then reinstall and tighten.</TD></TR></TABLE>
Maybe I should try this, my interior light has never cut on when the door opens, but does cut on when I manually switch it.
user 8508202243
Apr 29, 2012 03:33 PM
theorigkav3
Jul 12, 2011 11:54 AM
CivicBlack
Apr 24, 2006 11:08 PM
Scotty Dosent Know
May 25, 2005 12:15 AM
wishingiam
Mar 17, 2005 09:06 PM
