Interior Door panel removal... HELPPP !!!
Old Aug 15, 2002 | 08:52 AM
IdotheSHOCKER's Avatar
Default Interior Door panel removal... HELPPP !!!
Okay I got everything off the hooks but stuck on the part where the window control is... How to get it off and unhooked??
This gold piece is stuck to the window handle..... HOW TO REMOVE??
_______
Old Aug 15, 2002 | 08:55 AM
Spade's Avatar
Default Re: Interior Door panel removal... HELPPP !!! (EGB18hatch)
You unscrew the window handle and remove it.....
Old Aug 15, 2002 | 09:34 AM
Spade's Avatar
Default Re: Interior Door panel removal... HELPPP !!! (TYPE EG6)
no no no there is no screw !
on the panel side use a flat screw driver or needel nose plies and if you look you will see a gold clip holding it on pop the clip off and the handel will slide off !
be careful the clip likes to shoot across the gaage and get lost!
the clip is right ion the back of the handel on the panel side not behind it!
That works.
Old Aug 15, 2002 | 10:47 AM
BROOD's Avatar
There are window crank removal tools that help with that clip as well. Either that or small needle nose plieres will work. Good luck
[Modified by SLPR, 11:47 AM 8/15/2002]
Old Aug 15, 2002 | 11:40 AM
Default Re: Interior Door panel removal... HELPPP !!! (SLPR)
Thanks for the HELP! !!
Its gonna be fun putting the clips back in !!! Any tips??
BootcutSoldier
Oct 16, 2007 07:56 PM
Turboredteg
May 12, 2007 07:01 AM
themurrell
Feb 21, 2007 08:32 PM
kornerk12
Nov 12, 2006 06:21 PM
MxJones92
13
Jan 17, 2006 05:00 AM
