Installing Oil Pressure Gauge
Old Dec 31, 2003 | 02:30 PM
doublejz's Avatar
Default Installing Oil Pressure Gauge
Ok, I searched. What is the best way to run the oil pressure line. I was going to get a BSP T but I have read that they vibrate out or I was going to get a BSP adapter to NPT and run the tube to the firewall and T it there. Any suggestions will be helpful
Old Dec 31, 2003 | 02:55 PM
HAccord's Avatar
Default Re: Installing Oil Pressure Gauge (doublejz)
I would just go to autozone pick up the metric adapter set! 4.95! Get a T fitting and use some teflon paste or tape! it will be fine..
Sensor < _____ > Gauge
T
BLOCK
Old Dec 31, 2003 | 03:22 PM
RCautoworks's Avatar
Default Re: Installing Oil Pressure Gauge (HAccord)
I would defintly not run it directly off the block, I have seen bad things happen when its mounted right on the block. Here is how I have mine mounted.
Old Dec 31, 2003 | 04:13 PM
mmuller's Avatar
Mad Scientist
Default Re: Installing Oil Pressure Gauge (90blackcrx)
you need a bspt to npt adapter and i advice running a teflon braided hose and hook the oil pressure to there....
look at here:
https://honda-tech.com/zerothread?id=718486
Old Jan 1, 2004 | 11:44 AM
zelifcam's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HAccord &raquo;</TD></TR><TR><TD CLASS="quote">I would just go to autozone pick up the metric adapter set! 4.95! Get a T fitting and use some teflon paste or tape! it will be fine..
Sensor &lt; _____ &gt; Gauge
T
BLOCK</TD></TR></TABLE>
eh, bad idea. those cheap metric adapter fittings from Sunpro are made of brass and I tightened one down lightly in my block the other day and it completely sheered off inside my engine block due to it's shoddy press-fit construction. do not use these, they are not fun.
Old Jan 1, 2004 | 12:23 PM
Default Re: Installing Oil Pressure Gauge (zelifcam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zelifcam &raquo;</TD></TR><TR><TD CLASS="quote">
eh, bad idea. those cheap metric adapter fittings from Sunpro are made of brass and I tightened one down lightly in my block the other day and it completely sheered off inside my engine block due to it's shoddy press-fit construction. do not use these, they are not fun.</TD></TR></TABLE>
I have used many of these brass fittings and I have never had a problem with any of them. Are you sure you used the right fitting ?
Old Jan 1, 2004 | 01:22 PM
doublejz's Avatar
so if i would decide to go with an electrical guage, is there anyway I can splice in and use oem pressure switch or something, to avoid putting T in or something
Old Jan 1, 2004 | 01:23 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublejz &raquo;</TD></TR><TR><TD CLASS="quote">so if i would decide to go with an electrical guage, is there anyway I can splice in and use oem pressure switch or something, to avoid putting T in or something</TD></TR></TABLE>
No, you need to use the sender that comes with the gauge.
Old Jan 1, 2004 | 02:08 PM
doublejz's Avatar
so i would still have to go 1/8 bspt to npt then T then pressure switch and sender
Old Jan 1, 2004 | 02:50 PM
Yeah but don't mount it on the block, there was a picture floating around that would help you but I could not find it.
Old Jan 1, 2004 | 09:02 PM
LudeyKrus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">
I have used many of these brass fittings and I have never had a problem with any of them. Are you sure you used the right fitting ? </TD></TR></TABLE>
When I pulled my motor, the Sunpro tee I had used snapped in half in my hand when I simply very lightly grabbed the thing.
Old Jan 2, 2004 | 07:05 AM
crxluv2's Avatar
Default Re: Installing Oil Pressure Gauge (LudeyKrus)
http://crxluv2.fotki.com/oil_p....html
Old Jan 3, 2004 | 08:54 AM
GBRacing's Avatar
Default Re: Installing Oil Pressure Gauge (crxluv2)
So, where can I get one of these? It's the best unit I've seen so far!
Old Jan 3, 2004 | 10:04 AM
crxluv2's Avatar
Default Re: Installing Oil Pressure Gauge (ITACRX)
http://www.apgperformance.com
I'd imagine they could ship them. Not sure though.
Old Jan 3, 2004 | 10:11 AM
crxgator's Avatar
no offense but find a different shop...APG is bullshit and i hope they all go to hell and their store rots...
Old Jan 3, 2004 | 10:12 AM
crxluv2's Avatar
Default Re: Installing Oil Pressure Gauge (crxgator)
I agree but they have a cool oil pressure gauge.
Old Jan 3, 2004 | 10:45 AM
SiRex91's Avatar
I'd prefer not to give my money to APG, but it looks pretty damn nice. How much did that set you back? Do they stock those or is it just a one-off custom part?
Old Jan 3, 2004 | 12:00 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator &raquo;</TD></TR><TR><TD CLASS="quote">no offense but find a different shop...APG is bullshit and i hope they all go to hell and their store rots... </TD></TR></TABLE>
Just wondering why ? Not disagreeing with you, because I have dealt with them and they do rip people off but why do you hate them ?
Old Jan 3, 2004 | 02:32 PM
crxgator's Avatar
whats funny is it turns out this is a different APG than that website...the APG i hate is apgmotorsports.com, they ripped a friend off for $5000 and they are arogant little snobby ********...
Old Jan 3, 2004 | 03:15 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator &raquo;</TD></TR><TR><TD CLASS="quote">whats funny is it turns out this is a different APG than that website...the APG i hate is apgmotorsports.com, they ripped a friend off for $5000 and they are arogant little snobby ********... </TD></TR></TABLE>
I see, screw both of them then.
Built4Battle
Nov 2, 2011 11:39 AM
danny_civic97
Mar 12, 2007 01:00 PM
SOHCD16y8
Mar 26, 2004 05:04 PM
