Installing Mixture Gauge and A/F Meter
Old Mar 23, 2005 | 07:26 AM
Knightmare69's Avatar
Default Installing Mixture Gauge and A/F Meter
My friend is throwing a factory supercharger on his Nissan Frontier and wanted to know about installing a Mixture gauge and A/F meter. Where do the sensors for these 2 go? TIA.
Old Mar 23, 2005 | 07:55 AM
EE_Chris's Avatar
Default Re: Installing Mixture Gauge and A/F Meter (Knightmare69)
Your friend is using a true wideband O2 sensor - right?
If yes, install in the exhaust pipe before the catalytic converter.
If its not....throw it away.
What is a mixture gauge? Like a VAFC, or something similar?
Old Mar 23, 2005 | 08:41 AM
Default Re: Installing Mixture Gauge and A/F Meter (EE_Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">Your friend is using a true wideband O2 sensor - right?
What is a mixture gauge? Like a VAFC, or something similar?</TD></TR></TABLE>
no, he's not using a true wideband O2 sensor, what's a recommendation for one? Also, the mixture gauge is the lean/rich mixture that I'm talkin about
Old Mar 23, 2005 | 09:01 AM
littleRedCorvette's Avatar
teh a/f & mixture gauges are the same.
It's what you are hooking up to.
If you are putting the mixture gauge to the factory o2, it's basically useless.
If the mixture gauge is hooked up to or comes w/ the wideband, hook it up to that.
Depending on what else he is using, there are a few options for kits that I know of:
zeitronix
aem uego
lm-1 innovative motorsports
plx wideband
etc
etc
I think all of them (w/ exception of the aem?) use the bosch sensor, which is the relatively cheapest wideband sensor you can buy. And if you plan on running it in your car 24/7 (instead of just for tuning), then you will probably be replacing it yearly at least.
Old Mar 23, 2005 | 04:33 PM
PrettyLude's Avatar
Default Re: Installing Mixture Gauge and A/F Meter (littleRedCorvette)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by littleRedCorvette &raquo;</TD></TR><TR><TD CLASS="quote">
zeitronix
aem uego
plx wideband
etc
etc
Old Mar 24, 2005 | 09:54 AM
tgreaves's Avatar
Default Re: Installing Mixture Gauge and A/F Meter (PrettyLude)
Techedge..
CivicEJ1
Jan 6, 2005 11:41 PM
blacksh
Sep 10, 2003 05:56 AM
LudeyKrus
May 17, 2003 05:34 AM
photonjedi808
25
Apr 17, 2003 12:08 AM
