Installing ITR suspension on EG, do I need...
Old Jan 21, 2002 | 10:46 AM
WAFFLES's Avatar
Default Installing ITR suspension on EG, do I need...
the front LCAs from the ITR or rear only. I just purchased the suspension and I only have the rears(I assume). Do I need the fronts too? I searched and found nothing to answer my question.
Old Jan 21, 2002 | 10:54 AM
eg6ajk's Avatar
Default Re: Installing ITR suspension on EG, do I need... (WAFFLES)
you do not need anything more then knuckles for the front, but if you do want to install an ITR front or rear bar then you will need LCAs
Old Jan 21, 2002 | 10:57 AM
WAFFLES's Avatar
Default Re: Installing ITR suspension on EG, do I need... (eg6ajk)
ITR knuckles or stock?
I have---shocks/struts, springs, rear LCAs...nothing else?
Old Jan 21, 2002 | 11:52 AM
eg6ajk's Avatar
for the front:
complete knuckle with caliper/rotor combo, LCA only if you you installing a sway bar
rear:
complete trailing arms with caliper/rotor, as well as e-cables, brake hoses,
again LCA only if you are installing a rear sway bar (if itr LCA then ITR or JDM shocks will be required)
Old Jan 21, 2002 | 11:57 AM
WAFFLES's Avatar
I'm not changing everything over, just what I have listed. So then do I need the front ITR LCAs to fit the ITR shocks and springs on my car or not. I'm not changing the nuckle or any of that.
hazard_one
Suspension & Brakes
Apr 28, 2005 05:44 PM
AThiker
Feb 26, 2003 10:12 AM
EGTeK
Nov 15, 2002 09:06 AM
Mr. Softee
Jan 25, 2002 06:22 PM
