Need complete info on f/r lca and sway bars..
i did a search and didnt find all the info that i needed.
well i read some posts and it says that using rear itr lcas means that i need new itr shocks. well how about if i use front its lcas, will i need itr front shocks too?
what is the difference betwen the gsr and itr front\rear lcas..are the itr's that much better to go through the extra work?
people also reccommended the beaks kit, but someone else said that the only reason the subframe gets damaged is because of a soft suspension setup.
===how would this match up to a itr setup, because i ned to save money for my swap.
GSR Front/Rear LCAs
GSR Front Sway Bar
ITR Rear Sway Bar
Beaks EG Kit
Would you change anything?
thanks
GSR Front/Rear LCAs
GSR Front Sway Bar
ITR Rear Sway Bar
Beaks EG Kit
thanks
Re: Need complete info on f/r lca and sway bars.. (92CXHB)
i believe the itr forks(for the front) are the same as the gsr\civic.....
as for the rear, thats a good question i would someone to answer....
Re: Need complete info on f/r lca and sway bars.. (DOHCtorTHRUST)
The Fronts are the Same, The rears a defintally require differnt shocks, however if you just want lca's that will have sway bar mouonts and want to keep your shocks, you can some from a Del Sol Vtec (all Years) Del Sol Si (96-97) 94-01 Integra's GSR's and LS's, should bolt up and give you sway bar mounts, you can then use the Rear Sway bar form any of those cars or order one from suspension technicques or Salner.
Scotty Dosent Know
Suspension & Brakes
05-19-2006 07:35 AM
cyrk007
07-14-2003 03:26 PM
