Installing ITR cams
I'm gonna install my ITR cams in my LSVTEC and I need pretty much any kinda refference website or something from taking off the valve cover to installing the cams, to closing the valve cover. I need lots of detail, first time gonna do this, don't wanna screw up. little help anyone
EF2
LSVTEC
B16A1 Head
B16 Intake Manifold
ITR Pistons
ITR Cams
Modified by JhorickJFL at 11:20 PM 7/13/2004
EF2
LSVTEC
B16A1 Head
B16 Intake Manifold
ITR Pistons
ITR Cams
There are a few good write-ups here on Honda-Tech, however it's extremely simple to swap cams.
1. Set the engine to TDC
2. Remove the valve cover
3. Loosen the timing belt tensioner
4. Remove the timing belt
5. Remove the upper distributor bolt
6. Remove the cam cap bolts
7. Remove the cam caps
8. Remove the cams
9. Move the cam gears to the new cams
Installation is the reverse of removal in the most literal sense of the phrase. Just be sure to properly torque everything down and make sure that the timing belt is set correctly.
8. Remove the cams
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall »</TD></TR><TR><TD CLASS="quote">There are a few good write-ups here on Honda-Tech, however it's extremely simple to swap cams.
.</TD></TR></TABLE>
just take the old cams out and slide the new ones in. you dont need to take off the timing belt.
.</TD></TR></TABLE>
PURPLERANGER
Sep 9, 2014 12:19 AM
