input shaft bearing?
Old Aug 10, 2003 | 06:41 PM
mattcalica's Avatar
Default input shaft bearing?
okay, from what people have said in my previous posts, i am pretty sure my input shaft bearing is bad. my question is, how serious is the problem? will it damage the tranny, or will it just continue to make clicking noises? basically, do I HAVE to get it changed asap? or can i wait a while to change it out?
Old Aug 10, 2003 | 06:46 PM
mmuller's Avatar
Mad Scientist
Default Re: input shaft bearing? (mattcalica)
how long?it will end up messing up your tranny
Old Aug 10, 2003 | 06:55 PM
mattcalica's Avatar
umm, idk...i bought the car with 150,000 miles on it, and there was a slight clicking...now the car has about 154,000 and the clicking is a little louder...so idk how long before i bought the car that it was doing this.
Old Aug 10, 2003 | 07:21 PM
HONDADNA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattcalica &raquo;</TD></TR><TR><TD CLASS="quote">okay, from what people have said in my previous posts, i am pretty sure my input shaft bearing is bad. my question is, how serious is the problem? will it damage the tranny, or will it just continue to make clicking noises? basically, do I HAVE to get it changed asap? or can i wait a while to change it out?</TD></TR></TABLE>
To answer your question, I currently have d-series tanns ripped apart due to a input shaft bearing failure. Well he two waited the until it got worst. Now, not only does have to replace the input bear, he also has to replace the input shaft. The was damage due to excessive shaft movement when the bearing broke apart.
So, my advice to you is replace it now before it get expensive.
Old Aug 11, 2003 | 12:12 AM
mattcalica's Avatar
bump.
Old Sep 26, 2003 | 06:58 AM
Mr.DC2TurBo's Avatar
Default Re: input shaft bearing? (HONDADNA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDADNA &raquo;</TD></TR><TR><TD CLASS="quote">
So, my advice to you is replace it now before it get expensive.</TD></TR></TABLE>
How much does it cost to replace the input shaft bearing?
Old Sep 26, 2003 | 07:16 AM
HONDADNA's Avatar
Default Re: input shaft bearing? (Mr.DC2TurBo)
The seal it self is $25.00 and labor to replace it with tran already remove is $250.00.
Old Sep 26, 2003 | 07:18 AM
SoloSol's Avatar
Well shoot thats what I thought I had, a bad imput shaft bearing. If that right I have managed to get 80k+ miles on mine bought the car with 50k currently has 145k driven as hard as any street car could be.
Old Sep 26, 2003 | 09:58 AM
Mista Bone's Avatar
D Tranny Guru
$80 is what I charge to replace a unexploded ISB.
Exploded ISB replaced is about $125 IF the mainshaft is not damaged.
That means the tranny is dropped off at my place.
Do not let that bad ISB explode. This tranny is now JUNK.
Old Sep 26, 2003 | 10:06 AM
mmuller's Avatar
Mad Scientist
Default Re: input shaft bearing? (Mista Bone)
mista bone and trannys are like fat kids and cakes
Old Sep 26, 2003 | 01:13 PM
SoloSol's Avatar
Default Re: input shaft bearing? (mmuller)
I need to have someone listen to my car and tell me WTF is wrong. Bone- If I can record an audio file you think that you might be able to tell me what it is.?
Old Sep 26, 2003 | 02:17 PM
HONDADNA's Avatar
someone sure messed that one real bad.
civ_nate
Honda Civic (2001 - 2005)
May 29, 2007 02:43 PM
speedysohc
Apr 24, 2007 07:24 AM
solo-x
29
Aug 30, 2005 02:56 PM
nsxmatt
Jun 8, 2003 07:31 PM
