Ingnition wires??????????
Old Mar 16, 2003 | 07:04 PM
JALOP B16's Avatar
Default Ingnition wires??????????
Ok iv'e been looking at the taylor thurnder volts 10.4mm wires and they seem really good as in heat protecyion and less resistance.
But do I really need a wire that big is there any better wires out there cheaper.
($72) What are you guys using? btw I have a b16a i/e if any one needs to know the motor.
Old Mar 16, 2003 | 07:06 PM
TedR719's Avatar
Default Re: Ingnition wires?????????? (JALOP B16)
You can get the Magnecor's for the same price shipped http://www.groupbuycenter.com/buy.aspx?id=9201
Old Mar 16, 2003 | 07:07 PM
M-EJ1's Avatar
OEM wires... if you don't know if you need aftermarket wires, then you don't.
Old Mar 16, 2003 | 07:16 PM
JALOP B16's Avatar
Default Re: Ingnition wires?????????? (M-EJ1)
Im asking for the best for that price range. Not if I need them
And what people thought about the Taylors
Old Mar 16, 2003 | 07:22 PM
boostedcivicsir's Avatar
Mr. Badwrench
i have used taylors, magnecore, msd, and jacobs.
i have msd's on the BSiR. no probs with them either.
Old Mar 16, 2003 | 07:28 PM
JALOP B16's Avatar
Default Re: Ingnition wires?????????? (boostedcivicsir)
Okay thanks I guess ill be going w/the magnecore
Nology hot wire would be badass though.. Too much $$$ for wires
Old Apr 11, 2003 | 06:16 PM
92HB_HB's Avatar
had a set of nology's on a gsr i just bought.. man, one of the plugs on the distributor was shot to hell... when i pulled it off, the metal terminal was corroded beyond belief and broke right off from the wire itself... I dont know what caused it, but from what I seen from the NOLOGY's, I'd rather stick w/ oem or NGK...
gray_civic_coupe
Jan 9, 2006 10:51 PM
Reelizmpro
Oct 15, 2004 04:03 PM
EKCivicR
25
Aug 23, 2004 07:53 PM
jdmcivicferio
15
Aug 16, 2004 01:45 PM
