im having header problems
i have a 95 civic d15b single cam v tech i got my new headers today and went to install them but after i finishd and started it up i had a noise i pulld the car out the garage and test drove it thinking that it would just stop after pulling into the driveway i lookd under the car it lokkd like it was coming from the pipe like its vibrating or something anyway i found a vid off youtube im posting it so you can here hat im talking about i hope someone can help thanks
click on the second link to view vid its a diff motor but same problem thanks again
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/kIcZWuYncKA...</param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/kIcZWuYncKA&hl=en&fs=1&rel=0" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
You may not have torqued all the bolts tight enough which could explain the rattling sound. I wouldn't push it too hard because too much vibration could loosen bolts elsewhere. Check your Chilton or Haynes manual to get the exact torgue specs for the exhaust manifold.
