Ignition timing problem. Help!!!!!!!!!!!!!!!
Hi!!
I was reading the Shop Manual for a B16A first Generation (Using PR3 ECU) and went over to the timing setting's pages. They said that you must connect two wires (GRN/WHT and BLU) from the ECU before the adjustment. I did that but here are my two questions/problem:
1. What exeactly the two cables together do to the timing system/ECU that you must connect them togeter?
2. Why my timing is really away to the actual red mark? It really do not matter how much I advance/retard the ignition, never get even close to the red mark, only the white mark is the one that I can see with the light.
Here is the actual reading:
- White mark
- Timing light on pointer
- Red mark
This is around 700RPM.
As you can see, the actual reading sees the white mark over the pointer, but no matter how I move (advance/retard) the distributor, never got the pointer near the red mark.
I will appreciate any help on this matter!!
- White mark
- Red mark
the jumper keeps the ecu from altering the timing @ idle. it reduceds fluctuation so you can set the static ig. timing.
does this help?? https://honda-tech.com/zerothread?id=221612
Hi!!
Thanks for the help!!! I also have a weird sound inside of the head. It sounds that something were loose inside of the valvetrain. It is a metalic and continous sound during idle and low revs. A friend of mine told me that I probably need to adjust the valve clearance and know after reading your post, I guess that I'll check the timing too.
