Ignition Problem No Spark
Old Jan 13, 2010 | 06:24 PM
alex17's Avatar
Default Ignition Problem No Spark
Stock 94 Integra RS 5 speed.
Found a viper C60 Alarm under the dash, When I disconnect it the car does not crank, Not sure if they were smart enough to wire it into the ignition system as well, it does not seem like it.
I was driving to work when it just cut out, there is no spark. I can hear the fuel pump coming on and the Main relay smells good+clicks good. The ignition coil is getting 12v as well. What else can I check? A friend said it could be the ecu.
Any help would be welcomed.
Old Jan 14, 2010 | 12:06 PM
alex17's Avatar
Default Re: Ignition Problem No Spark
Wheres the fire?
Old Jan 14, 2010 | 12:14 PM
zedron's Avatar
Does the starter engage with the alarm is disconnected when you try to crank it?
Old Jan 19, 2010 | 11:02 AM
alex17's Avatar
Nope the starter does not engage when the alarm is disconnected. I bought another ECU and it started working, I plug in the original ECU it runs for about 3 seconds and doesn't run at all after that. The original does not look burned or smell bad, is there anywhere I can get it repaired for cheap?
B16B Four Door
Audio / Security / Video
Sep 19, 2015 06:23 PM
kon
Oct 19, 2005 11:34 PM
silvan
Aug 11, 2003 02:16 PM
Fuster_Cluck
Jul 18, 2003 04:56 PM
