Ignition problem, need help....
Old Jun 4, 2003 | 07:37 AM
autoEXturbo's Avatar
Default Ignition problem, need help....
Ok, heres the deal. The car was originally a automatic and sohc. It's now has a gsr motor and a 5spd swap in a 00civic coupe. The other day it went in it to get a new clutch and fly wheel. I drove the car home, the key was already in the ignition for me. When i got home and tried to turn the car off, the key went all the way back to the accessory position but then it wouldn't go back to the point where i could take the key out. So i tried to turn the car back, I could hear my excessively loud fuel pump turn on and everything worked, but the car still would not start, not even try and turn over. I disconnected the battery and then I was able to take the key out. If anybody has any idea why it's acting this way, i'd really appreciate any help you can give. Thanks.
Old Jun 4, 2003 | 09:16 AM
1_bad_EF's Avatar
Default Re: Ignition problem, need help.... (autoEXturbo)
it is the shift interlock mechanism.
Sounds like whoever did the install did not complete it or maybe knocked a wires loose or something.
Old Jun 4, 2003 | 09:22 AM
Default Re: Ignition problem, need help.... (1_bad_EF)
Do you know where that might be, if i can fix it myself i'd like to do so. Thanks for you help.
Old Jun 10, 2003 | 10:19 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1_bad_EF &raquo;</TD></TR><TR><TD CLASS="quote">it is the shift interlock mechanism.
Sounds like whoever did the install did not complete it or maybe knocked a wires loose or something. </TD></TR></TABLE>
Thanks for you help. That's exactly what it was. Just had to look over everything and it's working porperly agian.
pollofrito21
Apr 14, 2006 12:18 PM
bReEnAcCoRd
Sep 17, 2004 10:53 AM
typer464
Mar 25, 2002 09:39 PM
