Ignition Coil Test results question
2000 CRV with B20Z2 at 137,700 mi. Tested the igntion coil (part of a rough idle and timing issue diagnosis). Primary winding showing fluctation between 0.9-1.3 ohms (64° air temp). Manual I have says replace if not between 0.63-0.77 ohms (@ 68°). What say you folks?
BTW, Secondary winding ok @ 15.6 K ohms (spec 12.8-19.2).
What issues are you having? I remmeber checking mine as you have and the specs were slightly off as well. With the secondary in spec. Mine runs flawless Maybe try another test at the 68 degrees?
On a modern vehicle such as yours a scan tool is the only sure fire way to a quick and accurate diagnosis.
Otherwise you could be testing sensors up the wazoo looking for a fault....
nickelz34
Jan 2, 2013 04:42 AM
aalb1
Aug 7, 2005 10:50 PM
