idle/stalling
Old Mar 28, 2005 | 04:20 PM
BrownGSR's Avatar
Default idle/stalling
I just bought a 93 hatch w/ jdm b16 with a built head.
I didnt get it tuned yet, but runs fine
I pull in my spot last night and just tap the gas (1-2.5 rpms) and the needle falls down to almost 0, catchs and then returns to normal. It was really close to stalling
Any ideas???
Old Mar 28, 2005 | 04:22 PM
BACKintheDA's Avatar
Default Re: idle/stalling (BrownGSR)
i have the same problem.... and bump for the kid who bought my 5zigens
Old Mar 28, 2005 | 04:46 PM
BrownGSR's Avatar
Default Re: idle/stalling (BACKintheDA)
bump, the 5zigens are still on the teg, but looking good. Any ideas on this?
crower 401's
crower dual springs
crower ti retainers
skunk 2 gears
milled .020
bronze valve guides
skunk 2 hi comp valves
stock honda headgasket
stock bottom end/p30
Old Mar 28, 2005 | 06:08 PM
eda6's Avatar
I had the same problem a couple months ago. After replacing the dizzy and injectors the car still ran the same. So i put the old injectors and dizzy back on. When i was removing the fuel rail gas poured out of the vacuum line on the fpr. The diagphragm in the fpr looked like a pringle and wasn't doing it's job. Reassembled the fpr an my problem was gone.
If you have an adjustable fpr check that. I'd also check idle speed.
Old Mar 28, 2005 | 07:14 PM
zman's Avatar
Default Re: idle/stalling (eda6)
whats the cam gears set at? I had the same problem and it turned out to be too much valve overlap. Set the gears to 0 and see how she runs.
Could also be, idle air control valve, fast idle thermo valve, vacuum leak (although that would generally make the car idle high) or the fact that you have bigger than stock cams, honda's hate to idle with aftermarket cams.
1_bad_b18_acura
Apr 12, 2009 04:52 PM
robmobster2010
May 30, 2008 10:21 AM
Mr.Milton
Nov 24, 2007 09:09 AM
escourt23
Dec 15, 2005 06:59 PM
BrownGSR
Mar 28, 2005 05:10 PM
