anybody using 70mm tb and victor x mani having idle problems
what is the best way to fix the idle,im guessing adjust it,but could there be any other reason for it.
Re: anybody using 70mm tb and victor x mani having idle problems (PBOOSTIN)
Well you certainly don't give us much to work with. What idle problem are you experiencing? Fluctuation? Low idle?
New User
its the tps it needs to be readjusted and also check for vaccum leaks. I went through hell when i put mine on!
Re: anybody using 70mm tb and victor x mani having idle problems (RiTiCuLe)
a few thoughts, i have a victor x mainfold and a jg 65mm tb. a 70mm tb is HUGE its almost to big for a street driven car. from what i have heard its near imposible to get a good idle with a 70mm tb. but im sure it is possible tough. it is probly your tps sensor however. i got the jg edlebrock tb, and jg is so nice to put on a new tps sensor and adjust it for you!!! so all you have to do its bolt it up, no fooling around with the tps bs! good luck
