idle problems narrowed down to TPS
Old Aug 19, 2002 | 11:12 PM
Brian_92GSR's Avatar
New User
Default idle problems narrowed down to TPS
I was having some major idle problems when I first put on my victor x manifold. I narrowed it down to the TPS (by forgetting to plug it back in then the car idled fine) and have retuned the hondata. Everything is running perfectly, although it's idleing a bit high. HondaLogger shows the TPS voltage fluctuating slightly at idle when it is plugged in. Any explanation on why it would start doing that?
Old Aug 20, 2002 | 12:21 AM
C-speed's Avatar
Default Re: idle problems narrowed down to TPS (Brian_92GSR)
it may fluctuate +/- 0.01v at idle, thats normal.. just make sure you adjust it to read between 0.45v - 0.50v at idle and you are good to go.
Old Aug 20, 2002 | 12:56 AM
kinesistech's Avatar
Set it with the engine off. When the engine is running charging voltage varies. The voltage regulator is always adjusting. That can be seen on the sensors.
Old Aug 20, 2002 | 08:19 AM
New User
Default Re: idle problems narrowed down to TPS (G3-TEG)
How is it adjusted? It only fluctuates +/- 0.01v at idle, but when it is plugged in the idles goes up and down between 650 and 1250 rpm. With it unplugged the car idles fine.
Old Aug 21, 2002 | 03:06 PM
New User
Okay, I've tried another TB and when the TPS is hooked up it is doing the same thing. At idle RPMS go up and down between 500-1500. As soon as the TPS is disconnected everything is fine.
Old May 31, 2004 | 08:06 AM
lcaruca97's Avatar
back from the dead.......anyways. mine does this too. any ideas?
oh and mine is just a h22 im and tb
Modified by lcaruca97 at 6:57 PM 5/31/2004
Old May 31, 2004 | 03:57 PM
lcaruca97's Avatar
Default Re: idle problems narrowed down to TPS (lcaruca97)
dc4b20
22
Dec 3, 2012 09:54 PM
minner
Oct 8, 2006 01:30 PM
turbotime
Oct 24, 2005 12:01 PM
steve_s
Jan 22, 2003 02:06 AM
