idle problems
Old Apr 4, 2003 | 08:00 PM
Rain_man's Avatar
New User
Default idle problems
I'm having idle problems when when I start my car and it's cold. If I start the car and don't give it any gas, the car just dies. In order to get it to start, I have to give it gas and then hold it at 1500+ rpms or the car dies. After it warms up, the car will idle fine at 1100 rpms though.
Any idea what might be wrong?
Old Apr 4, 2003 | 08:28 PM
sslude's Avatar
Default Re: idle problems (Rain_man)
are you throwing a code? check all vaccuum lines and everything in a regular check up. check spark and the plug itself. hope that helps
Old Apr 4, 2003 | 09:28 PM
ULTRA911's Avatar
Default Re: idle problems (sslude)
sorta sounds like the iacv sensor is bad. you done anything to the intake system? and what motor?
Old Apr 5, 2003 | 01:23 AM
Rain_man's Avatar
New User
Default Re: idle problems (ULTRA911)
No code and the car is completely stock. I'm guessing vaccum leak or iac valve too. Any way to test a iac valve?
Old Apr 5, 2003 | 02:09 PM
7rrivera7's Avatar
unplug it. if nothing changes the sensor is bad.
Old Apr 5, 2003 | 02:58 PM
fathergoose's Avatar
Default Re: idle problems (7rrivera7)
if you had a vacuum leak the idle would be very high or up and down, looks like you have a bad sensor, but then again, no code...
Old Apr 5, 2003 | 04:41 PM
Turbo Powa's Avatar
Default Re: idle problems (fathergoose)
I had the same problem about a month ago. Its your IAC valve
Old Apr 5, 2003 | 05:39 PM
Rain_man's Avatar
New User
Default Re: idle problems (Panda EK)
Thanks guys, I'm going to try the iac valve test.
I was thinking maybe the fast thermo idle control too.
Old Apr 7, 2003 | 09:10 AM
JimBlake's Avatar
I think its more likely the fast idle thermo valve. The IACV is supposed to compensate for extra loads like A/C or heavy electrical usage. The thermo-valve is supposed to give you a fast idle on cold start.
Old Apr 7, 2003 | 11:09 AM
Turbo Powa's Avatar
Default Re: idle problems (JimBlake)
Sure about that? With my IACV disconnected I cant even start the car... It dies as soon as it starts. I had a bad IACV on my car and had to get it replaced but while I had a screwed up one thats the problem I had. And I had to idle it myself untill it got warm. I believe its the IACV.
Old Apr 8, 2003 | 04:03 AM
JimBlake's Avatar
Sure about that? With my IACV disconnected I cant even start the car... It dies as soon as it starts...
Well, that's what I thought... Maybe the IACV needs to be open some, too. The thermo-valve just opens when its cold, closes as it warms up. I guess both have to work together for cold starts.
Old Apr 8, 2003 | 08:45 AM
Turbo Powa's Avatar
let me know how it turns out
javifranks1987
Jul 1, 2014 06:07 PM
muffler man
Jul 14, 2009 02:27 PM
em1gangsta
Jan 26, 2008 03:40 PM
the.hamburglar
May 10, 2007 08:46 PM
pinoyboy204
Oct 5, 2003 08:12 PM
