idle keeps going up and down? why
Old Nov 11, 2003 | 04:13 PM
civicracer1993's Avatar
Default idle keeps going up and down? why
i put a zc in my 89 crx si .. all sensors are plugged in and i have right ecu. coolant was bled and there are no vacuum leaks . it will idle at like 2K for the first few mins then the idle will just go up and down by itself and wont stop unless i feed gas? i replaced all sensors but still does it. even changed the throttle body. any ideas? this is very annoying//
Old Nov 11, 2003 | 05:00 PM
vtekstorm's Avatar
Default Re: idle keeps going up and down? why (civicracer1993)
try the idle control valve usually those go bad
Old Nov 11, 2003 | 05:07 PM
Default Re: idle keeps going up and down? why (vtekstorm)
that was already replaced
Old Nov 11, 2003 | 05:21 PM
eky2k's Avatar
do you have a after market? have you checked the head gasket?
Old Nov 11, 2003 | 06:06 PM
LudaMan's Avatar
Look what I can do!
I had that similar problem with my 94 civic EX. My dad has a close friend who is a mechanic (helps for discounts) He said it was some gasket, cant quite remember what one, it was right next to the throttle control sensor. I know you said you replaced all your sensors, but check that gasket and maybe that might be the problem.
h-o-n-d-a
Aug 3, 2009 05:15 PM
95dc2teg
Sep 11, 2007 05:49 PM
go2sleep
Jun 27, 2006 01:36 PM
neXus dc4
May 15, 2004 12:04 PM
civicracer1993
Apr 2, 2004 08:10 PM
