idle fluctuation after warmed up
Old Feb 22, 2010 | 06:43 AM
nineD9eK's Avatar
Default idle fluctuation after warmed up
ok I have a 91 b18a1, wich currently has a hunting idle after warm up,
I have cleaned the iac, converted the car to obd1, with no difference.
The intake manifold is from a 92ls and none of the lines are currently hooked up but all
are capped off. What else could be causing this problem? should I try to hook up the lines?
I am trying to find a blown up picture of both manifolds and parts so I know where to hook them up. Any help would be greatly appreciated
Old Feb 22, 2010 | 06:48 AM
nineD9eK's Avatar
Default Re: idle fluctuation after warmed up
also has a oil catch can, and one of the lines goes into a hole on top of the intake mani by the injectors , but seems very loose could this be my culprit?
Old Feb 22, 2010 | 07:07 AM
kyden's Avatar
fitv.
Old Feb 22, 2010 | 02:17 PM
Str8EJ's Avatar
you need to make sure all of your vacuum lines are in place and in good condition.
dustinbs144
Jun 18, 2011 09:37 AM
Choppin
Mar 1, 2011 06:46 PM
Mr. LS VTEC
Oct 22, 2006 08:58 PM
Hybrid96EK
Jun 3, 2003 09:10 PM
AdamITR
Apr 1, 2003 10:31 PM
