IDLE... (All Issues Viewed)
Old Dec 19, 2005 | 04:31 PM
ILoveJDM.'s Avatar
Default IDLE... (All Issues Viewed)
I have had problems with my D16Z1 idling since i've had the car, and since, I have done the following...
1. No CEL's...
2. Bleed Coolant
3. New TB, TPS, MAP, IAT, FITV, adjusted my idle screw to only have it idle at 800
the lowest it will "drop" while surging, and 1100 to be the lowest it will "stay" when it wants... Which is very random.
4. Checked all vacuum lines, coolant lines, and did the FITV trick...
5. And if the IACV can go "bad" without throwing a code, that is my last guess, because the car will idle high cold, as if my FITV is working, and when I touch my gas pedal, it will begin surging? Sometimes it will begin to idle high, 1000, but wont keep a constant "low"... Or atleast even a non- surging idle. Any help is greatly appreciated as I have been doing all I have been aware of. Thanks
RinzEG6
Nov 24, 2014 12:02 PM
JSR
May 17, 2006 10:27 PM
ILoveJDM.
Dec 25, 2005 11:34 AM
UNKNOWN_MEMBER
Aug 11, 2005 08:55 PM
Civic Racer X 7
Jul 23, 2003 07:19 AM
