idle at 2k
Old Dec 27, 2003 | 11:07 AM
90hbvtec's Avatar
Default idle at 2k
b16a1 with 99 si intake manifold and STR TB on a 90 hb si
ok how do the lines on the iacv suppost to be hooked up....this is how its hooked up right now....coolant lines from the thermostat housing then i bypass that line to the left inlet on the iacv ..i think its supposrt to go on the TB then to the iacv, but since i have a STR TB it aint got a cold start..so then i jess ran it straight to the iacv then the right inlet of the iacv is hooked up to the block to where the coolant runs on the lower radiator hose..!!is that the right way...
is this the cause of high idle at 2k...moring starts are cool its at 900-1k..then as the motor gets warm then it goes to 2k and stays there..what could it be
Old Jan 15, 2004 | 07:51 PM
ibvietboi's Avatar
Default Re: idle at 2k (90hbvtec)
left side of the iavc comes from the tb (i bypassed mines so its coming from the top part of the motor) ...right side goes back in the block down below
im having problems too but i read somewhere and it might be my hondata..
dartonh22
Apr 3, 2008 11:53 AM
aoe_virus
Feb 19, 2006 01:01 PM
hybrid901
May 29, 2003 07:20 AM
Wicked Sol
Mar 6, 2003 05:49 AM
Tx92AccordExD
Jan 14, 2003 09:23 PM
