IACV replaced still code 14
Old Dec 27, 2005 | 09:40 PM
xkagax's Avatar
Default IACV replaced still code 14
like it says ^. replaced my IACV, this is the 3rd one I've tried, still code 14. Anything else that would cause it to shoot that code? Besides the IACV itself that is.
Old Dec 27, 2005 | 10:33 PM
SVOboy's Avatar
Someone on here just said he had a code 14 the ended up being a bad ecu. So try your ecu in another car mehbe.
Old Dec 28, 2005 | 07:21 AM
xkagax's Avatar
Default Re: (SVOboy)
I got a new ecu a few weeks ago, same ****. Even using my friends ecu in my car it still shoots the code for me.
Old Dec 28, 2005 | 11:24 AM
Black4thgenEF's Avatar
Default Re: (xkagax)
When my car was throwing that code it turned out that the two wires were backwards.
Old Dec 28, 2005 | 04:38 PM
rainforest's Avatar
Default Re: (Black4thgenEF)
did you get the code recently after the ecu was changed.
also check if you are getting battery voltage 12.7v to the yellow and black wire and body ground. if not yo have a open wire
if you have voltage check the ecu.
Old Dec 28, 2005 | 04:39 PM
rainforest's Avatar
Default Re: (rainforest)
my bad i dident see you swaped computers.
Old Dec 28, 2005 | 10:12 PM
xkagax's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black4thgenEF &raquo;</TD></TR><TR><TD CLASS="quote">When my car was throwing that code it turned out that the two wires were backwards.</TD></TR></TABLE>
? you didn't use the plug on the harness? I was thinking of running wires straight to the ecu if I can figure out which pins they are...
Old Dec 29, 2005 | 10:51 PM
xkagax's Avatar
anyone else?
Old Jan 12, 2006 | 11:43 AM
E36 Guy's Avatar
bump, same problem
Old Jan 12, 2006 | 12:14 PM
f2m0u5's Avatar
you might have used the wrong plugs.. i think the IACV plug has one blue/yellow wire and a yellow/black wire.. i had that code recently but found out i plug'd in the wrong sensor
Old Jan 12, 2006 | 09:29 PM
xkagax's Avatar
Default Re: (0LlY)
word I finally fixed it. Found a site called ff-squad.net. they tell you all the mods you need to do to make an obd1 b16a work for obd2 harness. So yeah if you use an auto harness like I did, you have to change some pins around and switch the plugs.
T--Rex
Jul 10, 2004 02:15 PM
brega3
Jun 30, 2003 03:43 PM
Si91CRXxX
Jun 9, 2003 05:48 AM
