I need help yet again, with Drv. side. LCA!!!! PLEASE HELP!!!!
Old Feb 13, 2004 | 07:57 PM
Se-rv-Tak's Avatar
Default I need help yet again, with Drv. side. LCA!!!! PLEASE HELP!!!!
I need help yet again with another problem I keep having with my driver side suspension. As some of you know, I was have problems with my half shaft not going in. Well that's all fine and dandy now, I took b20turbojason's advice.. and beat the **** out of it. haha.
Well, pretty much exactly where the Lower Control Arm, bolts up to the frame of the car, in between that bracket, It will no longer reach there. No matter what I do, I can't push the rotor, or any part of the LCA more toward the bracket to bolt it up. Has anyone had this problem before? I would show you pictures, but I do not have a Digi. cam. and my friend's mother has his. So I am screwed. Please help me out, yet again. I know i found 1 person to help me with the half-shaft, I can hopefully get some more help from other fellow H-T members! Please help! Thanx.
Old Feb 13, 2004 | 08:53 PM
Se-rv-Tak's Avatar
Default Re: I need help yet again, with Drv. side. LCA!!!! PLEASE HELP!!!! (Se-rv-Tak)
Bump!
Old Feb 14, 2004 | 02:51 AM
12345's Avatar
are you sure you're putting the right axel on....did you mix them up?
Old Feb 14, 2004 | 05:17 AM
Se-rv-Tak's Avatar
Default Re: I need help yet again, with Drv. side. LCA!!!! PLEASE HELP!!!! (12345)
Well, there is the intermidate shaft, on the drivers side. and then just a single half shaft on the passenger side. So ya, im positive it's the right axle. These poped right out of a 95 del-sol DOHC vtec. So I was told by many people they will work. so I am confused.
Old Feb 14, 2004 | 07:24 AM
Se-rv-Tak's Avatar
bump!
Old Feb 14, 2004 | 08:39 AM
suspendedHatch's Avatar
Sounds like the axle isn't all the way in the hub. Keep beating the **** out of it, or put the nut on it and tighten it down until it pulls the axle through.
Old Feb 14, 2004 | 09:17 AM
Se-rv-Tak's Avatar
Default Re: I need help yet again, with Drv. side. LCA!!!! PLEASE HELP!!!! (shaundrake)
the axle is completely through! tighten down and everything. it just seem's as if the axle is stopping the rotor from going back any.
Old Feb 15, 2004 | 06:55 PM
see_our_vtec's Avatar
we found out today the main problem. the del sol vtec's(b16's) have completely different driverside halfshafts than regular b series. and the intermediate shaft is different. we'll be trying to find a different intermediate shaft and half shaft here soon. but if any of you guys have a b series one. let us know.
undaj
Sep 5, 2013 11:41 AM
Type R 00
Feb 26, 2007 12:53 PM
