i need help with my turn signals.. please...
Ok.. i asked about a month ago and i still havent been able to fix my problem... my right signal always stays on after i turn on my parking lights, as long as all the lights are off they work fine.. but when the lights are on the right signal just stays on and doesnt flash.. i already checked the relay and its fine.. someone mentioned a ground wire... where do i find that?? im thinking i have an electrical problem.. but i just dont know where.. please help..
thanks
thanks
check the wires going into the bulb socket i find a lot of times those wires get jared loose. Start by jiggling the wires with the signals on if you see they start working get a new socket and wire it up
That one bulb has both filaments in it. There's 2 contact bumps on the base of the bulb, sometimes they get mashed together. Or maybe someone forced the bulb into the socket backwards.
Sounds to me as if your switch has went out. My car did this and also my wipers would stay on full blast. I had to replace both switchs on the sterring column. (The switch that contains the arms that stick out) Cost me about 160.
JDMEK-4
Mar 30, 2010 05:16 PM
JDMHondaEJ8
Jul 20, 2009 06:43 PM
