...help...
...help...
need your guys help.
ok i was messin around and tried to wire up my sidemarkers. and my dumbass accidently messed up some how made some wire touch each other.
now my turn signal doesnt blink. it stays on and all but no blink, but my emergency lights work and blinks. i check fuses, and the relay its still good and but no sign or blink turn signal. HELP ME PLZ
Re: ...help... (mikeycivic)
checked the bulbs everything, its still good. wired was never cut so its still wired correct ly. relay still good. i was think the only thing left to try is the turnsignal/light switch lever. u guy think it can be that?
Re: (envee)
yea. im pretty sure not the lights or nuthing cuz everything koo when i try to signal left or right nothing blinks, not even on the cluster. but when i try the emergency button it works. so yea im gunna go run to the junk yard and see if i can get that lever
I'm pretty sure that the bulb has 2 filaments. One for when the headlights come on and the second for blinker/emergency. Maybe one of them fried when you touched the wires?
Check the bulb again? Or just buy a new one, it's only a few bucks. I know in my mom's van the daytime corner bulbs came on but when she went to use her turn signals, it didn't work.
Re: (amej8)
ok before i go get anything. wat fuse shud i go check? and also no check engine light, when i turn the key on and also my temp and speed gueage doesnt work. i just check the2 filament on the blubs, both is still attach. this is really gettin on my nerves and i thank you all for helpin me out
Just curious but what was it? Just for future reference/knowledge if anyone else has this problem to recommend a solution or know how to fix it if it happens to one of my cars.
Imperious: Mod of Valor
Re: ...help... (lilsaigon510)
This sounds like a problem I had a few years ago when I was wiring up my city lights. It turns out it was the 'Back up light' fuse, I don't think it was called that exactly; but something like that.
Re: ...help... (JDM-EJ1)
yup the back up light fuse. i was kinda confuse. i was thinkin wth the back up light fuse gotta do with anything with the turn signal
ogawa_jiei
09-23-2006 06:10 PM
EM1Guru
11
10-24-2003 06:57 AM
