I know this is an ongoing topic.....
Old Apr 17, 2009 | 11:35 AM
1DayIllBFast's Avatar
Default I know this is an ongoing topic.....
I have a 96 JDM B18C with a high idle. I changed out the IACV for a different one it helped a little bit but not much. It idles around 1500-2000rpms it does not bounce. When we installed the motor we did compression test everything came out good, changed all plugs and wires, and checked for leaks. I Since my motor is a 96 I do not have a FITV so i cant check that. I have turned my idle screw all the way to the right. I dont know what else to do...also if i unplug the IACV the idle goes down to where it should and teh check engine light comes on so that tells me that its good and i also cleaned it out. someone please help.
Old Apr 17, 2009 | 04:49 PM
Blown90hatcH's Avatar
Default Re: I know this is an ongoing topic.....
Do you have slack in the throttle cable? Is the TB sticking?
Old Apr 17, 2009 | 05:38 PM
there really isnt much slack at all but i also don t think it is sticking either because when its cold its at like 1300 where it should be then once it warms up and i start to drive its at like 1800-2000
Old Apr 17, 2009 | 06:22 PM
PyroProblem's Avatar
Have you tried cleaning out your throttle body. Sometimes all the buildup on the blade and shaft can cause it to stick.
Old Apr 18, 2009 | 10:26 AM
no i have not tried this. i just got to my shop this morning and now im going to try and mess with it. if i cant find it i might just unplug the IACV leave it bolted on and plug in another IACV so i dont get a cel. because i did that just messing around the other day and it worked. There just isnt any change in cold start and warm up. its always at 800 ha
smurf357
Dec 2, 2012 11:33 AM
1DayIllBFast
Apr 17, 2009 05:42 PM
mike1114
Jul 6, 2006 07:15 PM
jdmkevin
Oct 7, 2004 07:06 PM
2000_Civic_Si
Sep 9, 2002 11:27 AM
