Rough Idle
Rough Idle
MY 95 Civic Ex has a rough idle. sometime the car willalmost cut off, sometimes it idles at 1200rpm. ive recently did a tune up wires plugs cap rotor fuel filter, pcv vavle , no aftermarket. does anyone know what it might be?
Re: Rough Idle (2000_Civic_Si)
it s idling low or high?....if low let the car warm up then adjust the title it is a little screw on the passenger side of the throttle body try that too high check to see if your throttle cable is sticking
Try cleaning the idle motor on the back of the intake. I have to clean mine this weekend and hopefully it will stop my car from idling rough.
The local shop said to take it clean it with brake cleaner.
