hydrolock question
Old Feb 14, 2003 | 09:55 AM
AH Tow EX's Avatar
Default hydrolock question
okay, i have a thread in integra, but it's slow right now, and i'm running out of time. https://honda-tech.com/zerothread?id=415431
thats the thread...
anyway, i just got finished draining the oil, and i took off my CAI found a little water all the way up to the TB. dried that out, and i looked at my oil and it looks normal, people said if you see white, you're fucked. but no white... my head looks perfectly normal, but i have yet to remove the spark plugs and crank it. so do you guys have any suggestions or something to say like "don't worry about it, everything looks fine, just do that and you'll be A-OKAY"... thanks guys!
Old Feb 14, 2003 | 11:10 AM
AH Tow EX's Avatar
Default Re: hydrolock question (AH Tow Ex)
bump!
Old Feb 14, 2003 | 11:36 AM
1SlowB16EF's Avatar
take the plugs out and rotate the motor by hand via the crank bolt if that feels good turn you motor over using the starter motor if that works well do a compression test... if the number are ok put your new plugs back in and you shoud be good to go as long as you have no electrial problems!
GOOD LUCK!
Old Feb 14, 2003 | 11:45 AM
AH Tow EX's Avatar
Default Re: hydrolock question (1SlowB16EF)
thanks a lot, i appreciate it! do you happen to have a picture of the exact bolt to use to crank the motor?
Old Feb 14, 2003 | 11:52 AM
10K2HVN's Avatar
the bolt that holds the crank pulley...
Old Feb 14, 2003 | 01:03 PM
AH Tow EX's Avatar
Default Re: hydrolock question (10K2HVN)
do i need to step in the clutch to crank the motor?
Old Feb 14, 2003 | 02:09 PM
GZERO's Avatar
if you are going to crank it (which is fine, i think!) take the injection fuse off and the spark plugs out and put towels there to absorb it
Old Feb 14, 2003 | 02:36 PM
sslude's Avatar
Default Re: hydrolock question (GZERO)
if you are aksing if your motor is hydrolocked, it's probably not. if you find a little water in your intake that wont hurt, you have to get the whole intake fully submerged (or close to fully submerged) in water to be hydrolocked
EF8DayDreamer
Jan 18, 2012 10:12 PM
sw96
14
Nov 8, 2009 11:05 PM
kapitalc
Apr 21, 2007 06:39 PM
the king.
Oct 19, 2006 12:09 PM
