hydro handbrake installed correctly?
Old Feb 14, 2012 | 05:14 AM
Listerofsmeg's Avatar
Default hydro handbrake installed correctly?
Hi All, i recently installed a hydro handbrake, in series with the regular brake system. So effectively i did it like this.
oem m/c to distribution block, distribution block to front brakes and also a line via a t block from the rear ports of distribution block to the handbrake m/c, then from there to the rear calipers.
I put new -3 lines in from the distribution block to the handbrake cylinder and then again from the cylinder to the rear brakes. However if you pull the handbrake (the systems been bled already) the rear wheels certainly do not lock easily, so i am wondering if i have done something incorrectly. There are no leaks, but the discs so have a little surface corrosion from where the car has been sat.
So, am i worrying myself about nothing? and once the surfaces have been scrubbed it will be ok? or have i missed something in the install. The handbrake does do "something" but i was just expecting a lot more....
Any advice, help appreciated
Old Feb 14, 2012 | 05:43 AM
grumblemarc's Avatar
The Grumpiest
Default Re: hydro handbrake installed correctly?
So why did we Frankenstein a hydro handbrake system on top of the existing one? Was there supposed to be some benefit to it? I have never heard of anyone doing this. Any links to working examples or it this totally custom?
Old Feb 14, 2012 | 06:09 AM
to ne honest it was the most common way that i came across it on the net. I had planned to isolate the rear brakes later on in the year so maybe i will just do that...
Old Feb 14, 2012 | 06:21 AM
fcm's Avatar
fcm
Old Fart
Also curious as why you would do this?
What is the advantage? 94
Old Feb 14, 2012 | 06:34 AM
The Grumpiest
For what purpose?
Old Feb 14, 2012 | 07:00 AM
to help staging/burnouts at the drag strip. The car is a drag car, but whilst maintaining the stock brake system for top speed runs.
Old Feb 14, 2012 | 07:07 AM
The Grumpiest
Please forgive me for being obtuse but I still don't know why that requires a whole separate handbrake system to do.
Old Feb 14, 2012 | 07:18 AM
my car was converted as it originally had drum rears, however the cable that were supplied did not work correctly with the car effectively leaving me with no handbrake. I decided to go for the hydro handbrake to try and give me the control back.
I could use some sort of line lock but thats only really useful for the burnout.
So to really answer your q, the cable brake was useless and i figured this would fix that, but at present it hasnt!
Old Feb 14, 2012 | 07:24 AM
kaiba's Avatar
Isn't hydro handbrake use mostly for drift car?
Old Feb 14, 2012 | 07:32 AM
drift and drag really. Looks like ive got it all plumbed in the right way, just might need to rebleed the system again.
Old Feb 14, 2012 | 09:43 AM
fcm's Avatar
fcm
Old Fart
You said the brakes where drum, I assume it means they are now disk, and if so, off what, a G3 Integra maybe?
If so then tech. they are already "hydro" hand brakes in the rear all you would need is the cable to "actuate" the hand brake slaves in the calipers.
This will allow you to lock up the rears to do burnouts, assuming the car is FWD, and still maintain normal braking for anything else. 94
Old Feb 14, 2012 | 10:09 AM
a stock handbrake is nothing to do with the hydro system in the car. The cable actuates a kind of hook that then pulls the caliper in on itself. No fluid in the system is moved, so is entirely seperate.
In a perfect world i probably should have persisted with the cable solution but this in theory should give just as good if not better control. As i say i think i just need to bleed the system better, less easy when its only me with no suction bleed kit
Old Feb 14, 2012 | 10:10 AM
and no the cables came off a delsol, so should have fitted my delsol just fine, but for whatever reason, they didnt, a couple of brackets were missing from the cables too which didnt help, but i should have been able to sort that.
hey ho...
Old Feb 14, 2012 | 06:57 PM
ekcoupeh22's Avatar
He installed a staging brake so he can preload his car at the line to take the shock off the drivetrain... I've seen it done this way so the pedal still applies to all 4 wheels and I've seen it as two different systems I personally prefer the pedal still doing all 4 bc I don't trust my hand not to lock up the rear tires.... Lot of people in here not familiar with a staging brake post this in the drag racing section
ATSMATT
May 20, 2010 08:06 AM
SCV_GSR
Dec 9, 2009 08:55 AM
calib17a
May 27, 2004 08:43 AM
