How safe are ITBS????
Old Aug 17, 2004 | 05:29 PM
pacifico's Avatar
Default How safe are ITBS????
is there any damage they can do to your motor? I know you can put little filters or something in them but are they bad on daily drivers even if tuned properly?
Old Aug 18, 2004 | 07:56 AM
pacifico's Avatar
Default Re: How safe are ITBS???? (pacifico)
Old Aug 18, 2004 | 02:22 PM
pacifico's Avatar
someones gotta have some info
Old Aug 18, 2004 | 04:39 PM
xEnderx's Avatar
I've heard that the Toda setup has to be adjusted alot.....plus you hav eto run a new EM system. Its a major major modification to do to a car, but when they work right.......umpf.
Old Aug 18, 2004 | 04:54 PM
user 996328629's Avatar
Default Re: How safe are ITBS???? (xEnderx)
shut up newb-
I ran them on a completly stock ecu and they ran fine.
Its all about the setup..
And for god sake...
SEARCH
Old Aug 18, 2004 | 05:32 PM
xEnderx's Avatar
Default Re: How safe are ITBS???? (Swags04)
Yeah......I'm a newb buddy. <rolleyes> You're exactly the kind of ******* that gives HT its horrible reputation for beign full of ********.
Old Aug 19, 2004 | 08:51 AM
pacifico's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xEnderx &raquo;</TD></TR><TR><TD CLASS="quote">Yeah......I'm a newb buddy. &lt;rolleyes&gt; You're exactly the kind of ******* that gives HT its horrible reputation for beign full of ********.</TD></TR></TABLE> and I did search!
Old Aug 19, 2004 | 08:59 AM
Zackyt's Avatar
i think there are some foam covers you can get for the street, i dunno about stock ecu either, personally if i was going to run itb's i would want it tuned on a dynomometer. Supposedly, one teaspoon of dirt in your intake tract is equivalent to like 80k miles of engine wear, just use common sense
Old Aug 19, 2004 | 09:38 AM
Kal's Avatar
Kal
Default Re: How safe are ITBS???? (Zackyt)
ITBs are quite safe as there are a number of companies that make filter covers for it. Running ITBs connected to a dump tube isn't a bad idea either... As long as the ITBs are working independently siphoning air from the dump tube with a filter, it will work. Tons of custom work though.
Old Aug 19, 2004 | 09:46 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pacifico &raquo;</TD></TR><TR><TD CLASS="quote"> and I did search!</TD></TR></TABLE>
Obviously not hard enough if you needed to ask this..
This topic has been coverd SO many times its rediculous.
Either way- ITB's are safe, just dont go driving threw dust clouds WOT
Old Aug 19, 2004 | 09:49 AM
Gearspeed-Performance's Avatar
Default Re: How safe are ITBS???? (Kal)
Anything is possible and can be made to filter them out. Some companies make airboxes that can be purchased separately to keep dirt from entering the intake ports.
Old Aug 19, 2004 | 10:04 AM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: How safe are ITBS???? (GearSpeedEF9)
i ran itbs for a year straight on my itr swaped hb with stock ecu and vafc and lots of tuning......not one single problem
Old Aug 23, 2004 | 11:35 AM
africanqueen's Avatar
Default Re: How safe are ITBS???? (HOOKUPS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HOOKUPS &raquo;</TD></TR><TR><TD CLASS="quote">i ran itbs for a year straight on my itr swaped hb with stock ecu and vafc and lots of tuning......not one single problem </TD></TR></TABLE>
Did you ever run your hatch in the 1320? What HP were you puttin down. I am thinking of ITB's but I am not sure. Just curious.
Old Aug 23, 2004 | 12:38 PM
vtec69's Avatar
if your worry about sucking stuff up with them then you could just get a filter kit for them
And there as safe as long as there tuned properlly
I highly doubt that they could be run on a stock ecu...........
But im no expert but I do know some people even with a hondata have a difficult time getting them to run properlly but that might just be me being a noober and now knowing anything
Old Aug 24, 2004 | 07:49 AM
Default Re: How safe are ITBS???? (vtec69)
Chris from Hookups Import Tek had them on a stock ECU and the car ran great. He drove that car all over the place with no problem and that car was a screamer on the road course!!!!!!!!!!
Old Aug 24, 2004 | 08:47 AM
DYNO-PRO
id have to look up the dyno chart but i believe it was 222hp with 139torque stock itr bottom end
Old Aug 25, 2004 | 10:17 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HOOKUPS &raquo;</TD></TR><TR><TD CLASS="quote">id have to look up the dyno chart but i believe it was 222hp with 139torque stock itr bottom end</TD></TR></TABLE>
Damn, that is some crazy HP.
deca
Oct 22, 2005 03:27 PM
ITR-2001
Jul 20, 2005 06:27 PM
Phil@SFP.net
May 17, 2005 06:24 PM
rhettdec
Mar 1, 2004 05:19 PM
nuro
Nov 14, 2003 06:48 PM
