How safe is CAI?
Old Jan 9, 2003 | 11:54 AM
killmystarrysky's Avatar
Default How safe is CAI?
I always hear the warning about CAI's in rainy weather. How much danger really exists, and what will happen if you have problems with it?
Old Jan 9, 2003 | 12:26 PM
HookUpsImportTek's Avatar
Default Re: How safe is CAI? (killmystarrysky)
It all depends on how low your car is and how much rain your area gets. If you have to drive through fairly deep puddles often then sticking with your stock air box OR short ram with a heatshield might be in your best interests. If you want some better flow out of your stock air box Spoon and K&N make good drop in filters ranging from $100 to $35 depending. Hope this helps. -HIT
[Modified by HookUpsImportTek, 1:27 PM 1/9/2003]
Old Jan 9, 2003 | 12:28 PM
Default Re: How safe is CAI? (HookUpsImportTek)
it is a 93 Civic HB, doesnt sit low (no lowering springs...actually somewhat rasied from the 17's).....but I live in Fllorida. As long as I avoid puddles, i should be alright? Is there any type of splash shield I can get?
577HondaPrelude's Avatar
The only way you can do any damge is if you submerge the hole filter under water, so it takes a really big puddle of water. However it could happen. If water just splashes on it, it will not hurt anything.
[Modified by 57STS, 4:29 PM 1/9/2003]
Old Jan 9, 2003 | 02:52 PM
lazy bum shaughn's Avatar
Default Re: How safe is CAI? (57STS)
You could consider getting a Comptech Icebox intake, but since it's almost $400 you could make your own.
Old Jan 9, 2003 | 04:15 PM
delslow94's Avatar
its not bad at all imo...i have had mine on for 3 years with out any problems. if you do get worried tho i guess u could get the bypass valve from aem
Old Jan 9, 2003 | 05:22 PM
sslude's Avatar
Default Re: How safe is CAI? (delslow94)
i dont think you should worry, i havevt had mine on for awhile.
Old Jan 9, 2003 | 06:31 PM
Benj's Avatar
Default Re: How safe is CAI? (zetarider)
You could also get an AEM bypass for your CAI, but I hear it doesn't always work?
Old Jan 9, 2003 | 06:40 PM
sslude's Avatar
Default Re: How safe is CAI? (Benj)
i heard that if your filter is submergerd in water, you have a 99.9% of your motor to hydrolock. but wtih the bypass valve, it's like a 70% chance. correct me if i am wrong
Old Jan 9, 2003 | 06:44 PM
gsrvx's Avatar
New User
While I was in the Bay Area....it rained a good deal...so just to be safe...I spent $25 on a stock intake. I didn't wanna risk anything...especially since my splashguard is torn up.
Old Jan 9, 2003 | 06:57 PM
sauceman's Avatar
Default Re: How safe is CAI? (RK)
I've swallowed enough water to stall my engine, but it didn't lock. I had it running on the starter for a while, and after 30 secs or so it caught back. Happenned twice. I changed the oil quickly after, and no other damages noticed. But I guess it's quite risky, so I moved the filter upwards. I'll move it back down this summer when it'll get dryer.
Old Jan 9, 2003 | 07:19 PM
Thanks for all the help, it is much apprechiated.
Ruskimafia
Jul 12, 2006 12:52 AM
numbnuts22715
Jul 4, 2005 01:21 PM
vtec95
Jan 8, 2003 04:53 PM
s0liDyNe
10
Sep 5, 2002 10:57 PM
kappy
14
Jun 29, 2001 02:57 PM
