How to remove bad gas?
Old Aug 7, 2003 | 02:15 PM
TurboJesse
Guest
Posts: n/a
Default How to remove bad gas?
The gas in my car has been sitting for about 6 months (last time it was started) any other ways to rid of it with out getting a mouth full of gas
Old Aug 8, 2003 | 07:33 AM
T4eg's Avatar
Default Re: How to remove bad gas? (Mpir3)
you could drop the tank.
Old Aug 8, 2003 | 09:12 AM
SleepyEG's Avatar
Default Re: How to remove bad gas? (BlueHatch00)
instead of using your mouth the start the vaccum, use a brake bleeder, or anything else that pulls a vaccum, or just use a clear piece of hose that's really long, and be careful
Old Aug 8, 2003 | 09:36 AM
Crazydave's Avatar
Default Re: How to remove bad gas? (SleepyEG)
grab a long tube..
stick it in the tank..
take a air nozzel attached to air compressor
put nozzel outlet on top of hose.. pointing AWAY FROM HOSE OPENING
= is the hose
NOZZEL--------->
wrap your hand around both openings..
after 20 secons or so.. gas should flow
Old Aug 8, 2003 | 10:13 AM
mph6563's Avatar
The tank may have a drain plug.
Old Aug 8, 2003 | 11:07 AM
RaYnE's Avatar
remember to chew your gum AFTER you suck it out..
Old Aug 8, 2003 | 12:59 PM
Benny Hinn's Avatar
Default Re: (Darkslide_08)
I know for a fact that the 88-91 cars have a drain plug Not 100% sure about a del sol, but I would think that they have one as well.
Old Aug 8, 2003 | 01:05 PM
piscorpio's Avatar
Default Re: How to remove bad gas? (mph6563)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mph6563 &raquo;</TD></TR><TR><TD CLASS="quote">The tank may have a drain plug.</TD></TR></TABLE>
Both my Civics had it 92/00.
Old Aug 8, 2003 | 01:18 PM
turbochic's Avatar
Default Re: How to remove bad gas? (piscorpio)
this is what i did, i dont know if its bad, but it worked, we disconnected the fuel line from i think where the fuel pressure gauge is, and made the hose longer then put the other end in a container, and you know when you put the key in and switch it to the 'on' position it is pressurizing the system? well we kept doing that and all the gas just came out through the hose into the container, until there wasnt that much coming out, then we just bought new gas with an octane booster and it worked fine. i tried to find a drain plug on my car...couldnt, maybe under all the plastic crap.
Old Aug 8, 2003 | 02:01 PM
hondapwr's Avatar
Kids, don't ever put automotive fluids in your mouth.. It's bad for you m'kay
Old Aug 8, 2003 | 04:11 PM
SpydermanGS-T's Avatar
Default Re: How to remove bad gas? (fmaxturbochic)
Thats about the best Idea yet on this thread...Unless there is a drain plug. Let the fuel pump pump it out! Thats my homegirl!!! Say SUP to the crew fo me...
Old Aug 8, 2003 | 04:50 PM
SleepyEG's Avatar
Default Re: How to remove bad gas? (SpydermanGS-T)
or you could just pull a vaccum with a brake bleeder, and it'd all come out!
Old Aug 8, 2003 | 04:53 PM
b18crx's Avatar
a match or zippo
Old Aug 8, 2003 | 07:58 PM
Mohudsolo's Avatar
Default Re: How to remove bad gas? (b18crx)
If the gas is just old, you can add fuel stabilizer to it. It has directions on how much to add to old gas after storage versus new gas before storing the car. If the gas was contaminated, consider removing the pump now to check the "sock" filter on the inlet. It could have a lot of crud in it.
kornerk12
Mar 18, 2007 09:13 AM
k4ff1n3
Jun 13, 2006 07:51 PM
folta2169
Aug 28, 2005 07:37 PM
elmalouno
Sep 13, 2003 10:03 PM
PiYoImuT
Jun 22, 2002 03:17 PM
