How much can you bore a B18B LS?
Old Feb 13, 2005 | 09:18 PM
j87w's Avatar
Default How much can you bore a B18B LS?
I have a stock bore B18B motor. The cylinders are not really worn but a little bit out of round. To be safe im going to bore it atleast .20 thousands. Would it be safe to bore it .40 thousandths? Sparkracing.com sells aftermarket ITR pistons in std, .20, and .40 is why I ask.
Thanks
J
Old Feb 14, 2005 | 07:11 AM
mmuller's Avatar
Mad Scientist
Default Re: How much can you bore a B18B LS? (j87w)
i would not go any more than 82mm
Old Feb 14, 2005 | 08:02 AM
SuzukaBlueAP2's Avatar
Default Re: How much can you bore a B18B LS? (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">i would not go any more than 82mm</TD></TR></TABLE>
you would not....but you didn't say cannot.
bwahahaha
Serisouly though, agreed. When you get up to 82mm-84mm, the cylinder walls are becoming very thin. If you want displacement, but a big block V8. If you want to make up for lost displacement, buy a turbo.
Old Feb 14, 2005 | 11:25 AM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
If you want displacement, get it resleeved.
Old Feb 14, 2005 | 05:27 PM
j87w's Avatar
Default Re: (MugenDude)
How much can I bore it without hurting anything? I want to bore it to 82mm.
Old Feb 14, 2005 | 05:30 PM
j87w's Avatar
Im going N/A, no nitrous, and no turbo. Its going to have a rev limiter of 8800.
Thanks
Old Feb 14, 2005 | 05:35 PM
GDM Z28's Avatar
.020 over for boost or .040 over for all motor....dont go more or the sleeves become too weak.
uses0ap
Mar 30, 2009 09:31 AM
89hatcher
Jul 11, 2007 11:48 PM
Shootinfor6s
Mar 5, 2007 02:35 PM
hotsuma23
Jan 31, 2007 05:32 PM
Orangecivic251
May 13, 2006 09:01 AM
