how much to bore block?
Old May 16, 2003 | 07:28 PM
95gsr's Avatar
Default how much to bore block?
how much will it cost me to bore my gsr block .25 mm for ctr pistons? or should i just bore it to 82mm and get differant pistons?
thanks Luis and will it cost more money depending on the size of the bore?
thanks Luis
Old May 16, 2003 | 08:05 PM
dfoxengr's Avatar
Default Re: how much to bore block? (95gsr)
.25 wont matter much. get different aftermarket high comp pists...
Old May 16, 2003 | 09:07 PM
9200RPM's Avatar
Bore as little as possible. The less you bore the more and more times you can reuse your block, unless you crack it. Not to jinx you or anything
Old May 18, 2003 | 02:27 PM
95gsr's Avatar
Default Re: how much to bore block? (TurboB16aEG)
ok but how much will it cost me to bore out the block .25mm thanks
Old May 18, 2003 | 02:30 PM
Kamin's Avatar
it varies depending on where you get it done
talk to local machine shops or engine builders.
Old May 18, 2003 | 03:24 PM
dc2dragster's Avatar
From: eastside of the beach, westside of the coast, Long Beach, CA, usa
take it to a machine shop itll probably be $10-20 a hole
Old May 18, 2003 | 05:07 PM
9200RPM's Avatar
Default Re: how much to bore block? (dc2dragster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2dragster &raquo;</TD></TR><TR><TD CLASS="quote">take it to a machine shop itll probably be $10-20 a hole </TD></TR></TABLE>
Thats about right....Mine were $20 each
Old May 18, 2003 | 05:43 PM
Broken Gearbox's Avatar
get the type r .25 os
Old May 19, 2003 | 07:11 PM
9200RPM's Avatar
Default Re: how much to bore block? (Powered By D15)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Powered By D15 &raquo;</TD></TR><TR><TD CLASS="quote">get the type r .25 os </TD></TR></TABLE>
Thats only .010" over...standard overbore is usually .020" isnt it.....
Old May 19, 2003 | 07:39 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboB16aEG &raquo;</TD></TR><TR><TD CLASS="quote">
Thats only .010" over...standard overbore is usually .020" isnt it.....</TD></TR></TABLE>
standard bore is when you get pistons that drop right in..so you dont bore at all...right?
Old May 19, 2003 | 08:39 PM
9200RPM's Avatar
Not standard bore...standard overbore....well there isnt really a standard overbore...i just ment that its the size most people go with when boring out the cylinders....
mtownek9
Oct 5, 2007 09:02 PM
brokeHonda
10
Oct 19, 2005 04:22 PM
SnOOpY-NO
Jan 12, 2005 08:09 AM
G_Man604
Dec 2, 2003 10:16 AM
roydogg
Aug 6, 2003 06:49 AM
