How to mount the distributor on a Mini-me and gasket remover
Old May 5, 2002 | 09:00 AM
noricercrx's Avatar
Default How to mount the distributor on a Mini-me and gasket remover
I'm in the process of the Mini-me and I am using the d16a6 distributor on the a d16z6 head. What is the best way to mount this. If I turn it wrong will it mess up my timing?
Also the old gasket is bi%*h to get off. I'm using a gasket remover and the process is really slow. Its an aluminum block so I can't use a metal scraper. Any ideas.
Old May 5, 2002 | 11:29 AM
rainforest's Avatar
Default Re: How to mount the distributor on a Mini-me and gasket remover (noricercrx)
it wont go in the wrong way the keys are designed so peolple cant do that. and the dist will just bolt on you will see where it goes. just look at the old on and then putit on like that.
crvglenn
Honda CR-V & Element
Sep 11, 2017 03:42 PM
numotive
Oct 12, 2007 02:08 PM
fe519
Apr 25, 2006 02:33 PM
noricercrx
May 13, 2004 09:55 PM
RTW DC2R
Sep 25, 2002 08:05 AM
