how to fix code 43
Old Dec 27, 2006 | 12:02 PM
Slow_import's Avatar
Default how to fix code 43
hey guys, had a post in the 92-00 civic forum but not too much info was given, just wondering if any of you guys have dealt with this code before and what was needed to fix it....code 43 is fuel supply....thanks for any info...
car bogs at like 3 grand and then feels really laggy til vtec hit. i know normally you can not feel vtec engage in the singlecam vtec's, but i think due to this problem, i'm losing alot of power before vtec, then when it hits, i get it all back but then the car seems to struggle between 6000-7000....my set up is a a6 block, z6 head, a6 tranny, z6 manifold, z6 dizzy wired with obd0 plugs, in a 90 si hatch with an obd1 conversion running a stock p28, i-e....
Old Dec 27, 2006 | 05:46 PM
Default Re: how to fix code 43 (Slow_import)
ttt....
Old Jan 2, 2007 | 02:01 AM
hondafiend's Avatar
try changing your spark-plugs and wires; if not ckeck your injecters for cracks.
Old Jan 3, 2007 | 07:38 AM
RA61825's Avatar
bump same code here
Old Jan 3, 2007 | 07:41 AM
EJgsr's Avatar
Default Re: how to fix code 43 (RACERX72)
check out all the filters and your injectors....
Old Jan 3, 2007 | 08:58 AM
jjspec's Avatar
Default Re: how to fix code 43 (USDMej1)
First check your fuel pressure to see if it is low.
StupidSlowRSX
Jan 18, 2009 05:38 AM
92BluEH-3
Nov 27, 2006 04:49 PM
DA BOSS
Oct 30, 2006 03:34 PM
El Ban
Apr 30, 2006 04:45 AM
gnar kill
Feb 20, 2006 12:28 PM
